1.8T ENGINE DIAGRAM
RE: 1.8T ENGINE DIAGRAM
Wasn't too bad, did it once took about 8 hrs started it up and realize I skipped a tooth, did it again took 3 hrs. First time was water pump too though. If you do this make sure you crank it over by hand to make sure tdc line up after a couple rotations...I forgot too the first time[:@]
All in all a good time!
Just take her clothes off and go for it...then carefully put her clothes back on. Use the tech article on audiworld and buy the ultimate timing belt kit from ecs tuning
