Engine Shuddering, Vacuum Leaks and Catalytic converter - AudiForums.com
Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Sponsored by:
Sponsored by:
Reply
Thread Tools Search this Thread
Old 02-16-2010, 09:54 PM
Default Engine Shuddering, Vacuum Leaks and Catalytic converter
Hello,
I was driving my car(2002 A4 3.0L Sedan) two days back and suddenly the CEL flashed a few times and car shuddered as long as the CEL flashed and then everything was normal again. Came back home and ran the engine codes. After numerous attempts to run the diagnostics (None of the inspection stations are able to connect to the OBD) I was able to connect once and here are the engine codes:
16815 - Warm Up Catalyst; Bank 2: Efficiency Below Threshold
P0431 - 001 - Upper Limit Exceeded
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded
16688 - Cylinder 4: Misfire Detected
P0304 - 001 - Upper Limit Exceeded
16689 - Cylinder 5: Misfire Detected
P0305 - 001 - Upper Limit Exceeded
Took it to a local mechanic and they cleared the codes and told me that the coils were okay and that catalytic converter did not pass readiness codes.
Took it to the dealer, and they say that there is a massive vacuum leak and because of the unstable idling it is causing, they are not able to connect to the controller to see what the issue with the cat is. Unless they fix the vacuum leaks (~350$), I've been told that no tests can be performed to see if the cat is functioning properly or not.
By Apr-10 I ll be out of federal emissions warranty. Can someone pls suggest if I should be getting the vacuum leaks fixed at the dealer? or if these issues are related or not?
Thanks,
krishna.
Reply
Thread Thread Starter Forum Replies Last Post
Methods for locating Vacuum leaks? Lmal355 B6 Models 5 04-25-2011 08:36 AM
troubleshooting/detecting leaks in vacuum system shoveland Audi A6 3 04-08-2009 01:54 PM
How to check for Vacuum leaks michaelh305 Audi A6 14 08-01-2008 10:55 AM
How do I check for vacuum leaks???? Audinick81 B6 Models 5 05-30-2008 01:39 AM
vacuum leaks?? quattro/2.8 Audi A4 12 05-13-2007 03:13 AM
Tags
30, 30l, a8, audi, car, catalytic, code, converter, efficiency, engine, forums, leakes, leaks, readiness, shuddering, vaccuum, vacum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
