Tuning after replacement Exhaut
You're looking for a 2.5 inch cat back with an X-pipe. Jeremy is correct, no tune is necessary to run an exhaust, BUT, once you have a 2.5 inch cat back with X-pipe, you should consider JHMotorsports tuning. The tune is about $600 but is specifically designed to work with a free flowing exhaust and frees up about 30-40 ponies. Any reputable exhaust shop should be able to get you what you need for under $600.
Also, while you're in there tearing stuff up, you need to "piggy pipe" your downpipes, that is, remove the pre-cat (the first one off the exhaust manifold).
