front diff oil filler location s4
RE: front diff oil filler location s4
Welcome to the forums!
You should try the S forum for this question or the technical forum. They are listed below this section. You'll get an answer pretty quick. There is also a search button above your post on this page. Put the key words in your question into it and you will have an answer even faster.
thanks I got lucky, or maybe not.
My son was going to change the engine oil and drained what ever is in the flat pan with the drain in the middle, which is either the trans ( we have an automatic) or a diff of some sort (quattro) now that I got involved I have to put some oil back, the oil that came out seams to be not atf but some kind of motor oil and I need to know where the fill hole and how many qts to put back.
I found the fill hole in front of the cv on the pass. side of the car but I'm not sure if that will fill the area where the pan is.??????????????????????
