AudiForums.com
Go Back   AudiForums.com > Audi Tech > Nitrous, Super Chargers, & Turbos
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Parts Search Today's Posts Mark Forums Read ExperienceGarageUsed CarsVendors TSBs
Search
Welcome to AudiForums.com
Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
Reply
LinkBack Thread Tools Search this Thread
Old 03-08-2007, 03:01 PM
Default my 12v v6 rear mount turbo setup is done
Im only alowing 2psi of boost right now, however even on that boost level I was able to keep up with a ls1 convertible vette with a really fat driver, he was PISSED OFF hahaha. That seems like low boost and it is, but the turbo im using is rather large, the pictures dont really do it justice. The car sounds rather stock until you floor it, then it sounds like a jet engine roaring down the street oh yea it runs very reliably and idles just like stock too
[IMG]local://upfiles/32036/065F196D2BD441189D054DF020396715.jpg[/IMG]
[IMG]local://upfiles/32036/365F1D4F265140CFB0FA34987E2F3510.jpg[/IMG]
[IMG]local://upfiles/32036/C3C9184289EF42E58EEC5F772B93BC6B.jpg[/IMG]
Old 03-08-2007, 05:39 PM
Default RE: my 12v v6 rear mount turbo setup is done
question...are there any benefits to a rear mount? i know they make those kits for vettes, but i have never seen one in person. seems like a hell of alot of extra piping for the same result.
__________________
1998 A4 1.8TQ - KO4, Unitronics, 380cc's, Intake, 18's, dropped, 1 piece Projectors w/ HID's, grill, Forge007, ARP snub, custom 2.5" exhaust, FMIC, piggie SOLD Sept '08
Old 03-08-2007, 06:45 PM
The turbo stays cooler and can be larger because its not in the engine compartment. I chose this route because it was the least amount of down time in the install for my car. Durring the install the most time the car was not able to run was 4 hrs. (I did the install in many parts) The underhood heat is also kept down. On the down side I did loose 2" of ground clearance but it hasnt been a problem yet, I can look past that for now.[/align]
Old 03-08-2007, 09:12 PM
nice has it been tuned or are you just running stock tuning?
__________________
Old 03-09-2007, 11:04 AM
Where is your turbo inlet at? Is it just the filter on the turbo, or do you have a sort of an intake tucked away into the bumper? Just a question since it's still not that great of weather permanately for the season
__________________
I dream of RS4...then I wake up and have to change my sheets.
Stock '98 A4 2.8Quattro Sport, Tiptronic, Disconnected Taillight mod, Silverstars because I'm too poor to buy H.I.D's, Freshly Rebuilt Tranny
Old 03-09-2007, 11:17 AM
Is it possible to ummm...dent in the underside so you can have a nice channel for the boost tubing? I know it might sound barbaric, but it's just a question.
__________________
Old 03-09-2007, 05:31 PM
The engine has a piggy back apexi fuel computer. The charge piping does hang down some but not too bad. The filter is on the maf which is on the turbo inlet, and there is an air box around the whole thing.
Old 03-09-2007, 10:21 PM
cincyTT's Avatar
I'm make believe
Points: 12,582, Level: 73
Points: 12,582, Level: 73 Points: 12,582, Level: 73 Points: 12,582, Level: 73
Level up: 33%, 268 Points needed
Level up: 33% Level up: 33% Level up: 33%
Daily Activity: 0%
Daily Activity: 0% Daily Activity: 0% Daily Activity: 0%
if you have a safc i hope you are funning more that 2psi now. 5-7psi should be fine if you can tune it right. You may even want to up the fuel pressure to keep a/f around 11:1-11.5:1, which you should also be keeping an eye on.
__________________
A TT, A4, and TDI Bug... I live under these cars
Old 03-09-2007, 10:29 PM
All that & you have 2 psi?
I bet it takes some time to spool up & you must have massive lag. A turbo works off of thermal compression. Putting it way back there, the exhaust cools a LOT, causing the flow to slow down. That's why most turbo's are right off the manifold. yes, it will run cooler back there, but your getting far less efficiency from it.
Then you have all that piping, do you have a IC? I hope you never scrap anything on the underside of the car. Boost leaks are going to plague you.
You can gain more performance from one of the E-ram electric superchargers over your setup.
Sorry if you think I'm being a little mean, but if your not going to due it right, why even do it?
__________________
If you PM me waning help, PayPal $5 to evoiiim3@yahoo.com first!
2005 Lighting Yellow Lancer EVO 8
2000 Audi S4 Imola Yellow
1997 Porsche 911 C4S, Black
Old 03-10-2007, 12:55 AM
cincyTT's Avatar
I'm make believe
Daily Activity: 0%
sorry but im going to have to refute some of these points
Quote:
ORIGINAL: 2k S4
All that & you have 2 psi? Agreed
From the pic it looks like its before or replacing the cat
theturbo works on flow, thats why a larger displacement engine makes more exhaust flow spooling a turbo faster.
That's why most turbo's are right off the manifold. yes NO, they are there because of space and they spool faster., it will run cooler back there, but your getting far less efficiency from it. Not really,it gets a much more even flow like a equal lenght manifold. Which although slower in spool (pending how far back it is) you gain more high end hp.
Then you have all that piping, do you have a IC? I hope you never scrap anything on the underside of the car. Boost leaks are going to plague you. He is not even above 7psi. He would be fine until he passes that. Plus he would only need a smaller ic because he is using a larger turbo at very little boost causing very little heat.
You can gain more performance from one of the E-ram electric superchargers over your setup. I really hope that was a joke. A large turbo flows way more cfm then a plastic fan
__________________
Reply
Tags
12v, 26, 28, a4, a6, ar, audi, inlet, manifold, mount, rear, rebuile, sale, setup, turbo, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
New Sponsors
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
© Internet Brands, Inc.
Emails Backup
