4.2L Drivers, it’s your turn. Presenting the 2013+ AWE Tuning R8 V8 SwitchPath™ Exhau
The Audi R8 4.2L SwitchPath™ Exhaust sets a new standard. Beyond the hand crafted detail that is standard for every AWE Tuning Performance Exhaust, this one packs a little something special with SwitchPath™ Technology.
The highlights:
If you have an R8 4.2L and you're looking to make one of the most meaningful evolutions available, this is your move.
Civil. And disobedient. All in one.
More information about the AWE Tuning 2013+ R8 V8 SwitchPath™ Exhaust here, or talk to an AWE Tuning Audi Performance Specialist at 1.888.565.2257, 215.658.1670 or performance@AWE-Tuning.com.
The highlights:
- SwitchPath™ design allows driver to select volume with in-cabin remote toggle
- 25 hp / 28 ft-lb @ 4700 rpm
- 24 lb weight savings with SwitchPath™ System
- German Engineered control valves
- Valve programming optimized for R8 engine characteristics
- CNC machined V-Band connections
- Crafted from T304 stainless steel
- No Check Engine Light - Guaranteed
- Designed and manufactured in-house at AWE Tuning
- Fitment - Guaranteed
- Lifetime Warranty
- Under part throttle and idle, valves route exhaust gasses through a central muffler, keeping sound tame and drone free.
- At 3/4 throttle application and more, the valves open and the system is unleashed – going into "straight pipe" mode.
- An in-cabin mounted electronic SwitchPath™ Remote toggles the mechanical valves between "normal" and "straight pipe mode." Practical.
Andrew/AWE
11-12-2014 03:29 PM
Andrew/AWE
07-10-2013 04:34 PM
Alex/AWE
05-13-2011 03:43 PM
