05.5 S4 Part Out- Engine Failure
Just received word from my shop that the timing tensioner broke. Going to cut my losses instead of paying a hefty repair bill.
Parting out the complete car. 2005.5 B7 Avant
Fourtitude.com - Is my S4 done for?
Inquiries to partspetro@gmail.com
PARTS LIST
Engine Related Parts
AC Dehydrator
Air Snorkel (Intake Tube)
Air Tube (MAF to Throttle Body)
Auxiliary Radiator (Driver)
Auxiliary Radiator Schrouds
Axles (All - Automatic)
Axle Heat Shields (Automatic)
Cabin Filter Housing
Coilpacks
Cold Air Intake
Crank Pulley (OEM)
Differential
Dipstick
Drive Shaft
ECU Housing (Black Box)
Engine Wiring Harness
Engine Mount
Exhaust Sleeves (Downpipes to Catback)
Fuel Rail
Idler Pulley
Injectors (8)
Mass Airflow Sensor (MAF)
Oil Cap
Power Steering Pump
Radiator Fan (Large)
Snub Mount (Stock)
Snub Mount Bracket
Starter
Transmission (Automatic)
Transmission Mounts
Waterpump & Housing
Weather Stripping (Engine Bay)
Interior Related Parts
Amplifier (Bose)
Ashtray (Front)
Airbag (Passenger Dash)
Airbag Control Module
Airbag Impact Sensors
Antenna Booster
CD Changer (Glovebox)
Cluster Trim Piece
Central Control Module
Dashboard
Dashboard Vents
Deadpedal
Door Wiring Harnesses
E-Brake Handle
Electronic Relays
First Aid Kit
Gear Selector Unit (Auto)
Hazard Button
Homelink Module
Hood Release Lever
Memory Seat Module
Tool Kit (Trunk)
Radio Cage
Radio Trim (Upper)
Rear Key Lock Button
Seat Belts (Black)
Steering Wheel (MFSW 4 Spoke w/ Airbag)
Steering Wheel Cover / Surround
Steering Wheel Clockspring
Steering Wheel Control Module
Steering Wheel Stalks
Subwoofer (Bose)
Sunroof Motor
Welcome Home Module
Window Motors (All)
Window Regulators (Rears)
Other Parts Misc
ABS Pump
Brake Fluid Reservoir
Exhaust Hangers
Fuel Door Cover
Gas Cap
Hatch (Rear Avant)
Hatch Struts
Hatch Wiper Motor
Horns
Power Steering Reservoir
Radiator Fan Control Module
Rear Shocks
Shock Tower Plates
Side View Mirror Glass
Side View Mirror Motors
Sways (OEM S4)
Windshield Washer Pumps
Wiper Transmission
Wheel Lock Kit
PARTS LIST
AC Dehydrator
Coilpacks
Cold Air Intake
Crank Pulley (OEM)
Differential
Dipstick
Drive Shaft
Engine Mount
Fuel Rail
Idler Pulley
Injectors (8)
Oil Cap
Power Steering Pump
Snub Mount (Stock)
Snub Mount Bracket
Starter
Transmission Mounts
Waterpump & Housing
Amplifier (Bose)
Ashtray (Front)
Antenna Booster
Cluster Trim Piece
Dashboard
Dashboard Vents
Deadpedal
E-Brake Handle
Electronic Relays
First Aid Kit
Hazard Button
Homelink Module
Hood Release Lever
Memory Seat Module
Tool Kit (Trunk)
Radio Cage
Radio Trim (Upper)
Seat Belts (Black)
Subwoofer (Bose)
Sunroof Motor
Welcome Home Module
Window Motors (All)
Other Parts Misc
ABS Pump
Exhaust Hangers
Fuel Door Cover
Gas Cap
Hatch (Rear Avant)
Hatch Struts
Hatch Wiper Motor
Horns
Rear Shocks
Shock Tower Plates
Sways (OEM S4)
Wiper Transmission
Wheel Lock Kit
10kRedline
05-06-2010 06:29 PM
