door panel removal
door panel removal
anyone know how to remove the door panels on a 2000 b5 s4?? i need to replace the window lock switch. it is stuck in the locked position and the only way someone in the back can put down their window is if i hold the button in. thanks
RE: door panel removal
If I remember correctly all you need is a phillips screw driver to take the door off. Take out screws and the panel will pull towards you alittle and up. One of the screws is under a plastic finish panel where you pull to close the door.
Good luck
Good luck
