grinding noise
grinding noise
I have a 2000 S4. I drove it to school this morning and after class i went out and started it and noticed a grinding noise coming from the engine. It doesnt sound like it is coming from the tubos but it could be. I have never heard this before. Also it is not consistant noise. After checking things out i notice that the check computer light came on. I was wondering what could be causing this noise could be?
RE: grinding noise
do you have a VAG-Com or access to one? You could also take it to Autozone to have the CEL code scanned. If the light is flashing then DO NOT drive the car anymore, have it towed to a mechanic. If you get the code post it here, and i'll try to help.
RE: grinding noise
Alright I found out what the codes are
P1136- Bank 1 Mixture adaption too lean
P1347- Bank 2 Crank/Cam Sensor out of sequence
P0300- Cyl. misfire Detected
Would any of these cause the noise that i am hearing from my engine?
