:: GruvenParts A4 B5/6/7/8 SPC 81350 Adjustable Front Control Arms and More !!
#31
BPY Engine Upper Rad Hose Billet 4Y Fitting!
GruvenParts.com is happy to release our Billet Upper Radiator Hose 4Y Coolant Fittings for VW Golf/Jetta/Passat/EOS and Audi TT/A3 with BPY Engine -- P/N 1K0-121-087H (1K0121087H).
The OEM plastic 4Y connector used in the upper radiator hose is prone to cracking and leaking which often results in a rapid loss of coolant which can permanently damage your motor.
The GruvenParts.com billet 4Y Pipe is machined from Aircraft Grade 6061-T651 Aluminum, professionally TIG welded, and then pressure checked by our licensed welders. This one will permanently stop the nonsense caused by the VW/Audi cheap plastic coolant fitting.
This billet 4Y Pipe is intended to replace the plastic 4Y fitting OEM P/N 1K0-121-087H (1K0121087H) found in the upper radiator hose of the BPY Engine Code VW's and Audis :
VW EOS 07-11
VW Jetta 05-10
VW Golf 06-12
VW Passat 06-08
Audi A3 05-12
Audi TT 07-12
VW EOS 07-11
VW Jetta 05-10
VW Golf 06-12
VW Passat 06-08
Audi A3 05-12
Audi TT 07-12
#32
"Introducing the GruvenParts.com Upgraded MKIV VR6 Intake Manifold Trifecta -- A SURE Bet !
These parts replace the cheap plastic parts associated with the following intake manifold drive units -
021-133-653 (021133653) on 2.8L 12V VR6 engines - 1999-2006 Golf, Jetta, Jetta Wagon, Vanagon
022-133-653 (022133653) on 2.8L 24V VR6 engines - 2002 on Golf, Jetta, Jetta Wagon, Vanagon
022-133-653B (022133653B) on 3.2L 24V VR6 engines - Touareg, R32, Eos
MKIV VR6 Intake Manifold Bushings - 12V and 24V VR6 Engines - Click the Pic !
Unbeatable Tite-Loc bushings are made to precisely mate with your intake manifold and prevent rattles and expensive damage to the manifold bore. Replace the cheap VW/Audi rod bushings with these BEFORE rattling begins to save your upper intake manifold !
MKIV VR6 Intake Manifold Drive Ball - All VR6 Engines - Click the Pic !
A 6061-T651 billet version of the flimsy plastic drive ball which is crucial to your VR6 variable intake manifold system. Don't spend more on a plastic part than the lifetime billet version !
MKIV VR6 Intake Manifold Drive Linkage - All VR6 Engines - Click the Pic !
A 6061-T651 billet version of the flimsy plastic drive link which is crucial to your VR6 variable intake manifold system. Don't spend more on a plastic part than our lifetime billet version !"
#33
TT/R32 Rear Adjustable Control Arms
Click on the picture to visit our product page for up to date pricing info.
CHOOSE POLY-BUSHINGS OR SPHERICAL ROD ENDS !!
Got a lowered TT or R32 ? Then you already know how the camber and toe become completely out of sorts, causing poor handling and expensive tire wear the more its lowered.
The GruvenParts adjustable control arms allow for complete rear wheel alignment and feature the following :
Choose from a zero deflection high radial load PTFE lined inboard spherical joint with protective dust boots preinstalled over specially machined bushings. The fit of the boot over the spherical joint and bushings is nearly water tight!
OR
A poly bushing inboard end made from heat treated 4340 forged chromoly housing, thread in grease fitting, zinc plated steel protective sleeves, and race grade greaseable black polyurethane bushings from Energy Suspension.
You decide which set up you want ! The zero deflection spherical joints are suited for serious track abuse while the poly bushing ends are better suited for daily drivers.
All GruvenParts control arms feature the following :
Super strong, heat treated 4340 aircraft grade chromoly rod and ผ thick U-Joints with machined, internally lubricated (molybdenum disulfide) threads. No weak aluminum is used for these parts (aluminum threads wont hold up).
Distinct proper wrench adjustment flats machined into the bars which allow for 2 of length adjustment while on the car. There is no knurled hand adjustment nonsense here, ours are simple to adjust.
Thick, durable powder coat finish (and zinc plating on the poly bushing ends) in your choice of high gloss black or Bilstein jazz blue.
Made right here in Atlanta, Georgia by our FAA approved commercial aviation machine shop working on state of the art CNC mills and lathes. You wont find many shops working at our level, and you wont find higher quality anywhere !
We know the economy is tough right now, so we are offering these at prices well under our competition. Buy 2 sets and save !!!
This product fits Audi TT (2001-2006), Audi A3/S3, VW R32 (2004), VW Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant and replaces P/N 1J0-505-323L (1J0505323L) and 1J0-505-323N (1J0505323N).
***Save Big $ when buying these in conjunction with our Adjustable Rear Swaybar End Links and our Adjustable Front Swaybar End Links
...And finally...
TT/R32 Rear Adjustable Control Arm Hardware
Need to buy 1 offs for a project? Want new/longer fasteners? Look below for the parts to get the job done!
- High radial load GENUINE FK JMX Series PTFE lined heim joint kits
- Custom 4340 Forged, Heat Treated poly bushing ends with Rolled Threads
- Racing Grade protective rubber dust boots for พ heim joints
- Longer bolt kits - 80mm in length, grade 8.8, zinc plated
- Headlight Leveling System Bracket"
OR
...And finally...
#34
Our version is machined here in house on one of our state of the art HAAS milling centers and carries a LIFETIME WARRANTY ! This part is milled from Aircraft Grade 6061-T651 Billet Aluminum and includes 4 preinstalled Viton O-Rings for maximum durability.
The plastic OEM tube often breaks due to heat degradation causing coolant leaks that could lead to the ultimate failure of the engine.
Because this part requires a great deal of labor to get at, you should always install this Lifetime Warranted Billet Aluminum version when doing this job. Click the product page to also view a complete DIY on the replacement procedure.
gruvenparts.com
10-14-2016 01:05 PM
gruvenparts.com
10-14-2016 01:01 PM
gruvenparts.com
10-14-2016 01:00 PM
gruvenparts.com
10-12-2016 12:15 PM
gruvenparts.com
10-12-2016 12:14 PM
