Skipping or missing after an engine wash: S6 Wagon 1995.5
Old 05-09-2008, 05:28 PM
bennettcorp5's Avatar
Default Skipping or missing after an engine wash: S6 Wagon 1995.5
I had my car detailed, the engine was washed, now it missing or skipping. Has anyone else had this problem? Any ideas?
Old 05-09-2008, 05:42 PM
pdq 5oh's Avatar
Default RE: Skipping or missing after an engine wash: S6 Wagon 1995.5
Check the spark plug boots. Water probably got down in there and is grounding the spark. Spark will always take the path of least resistance to ground. The spark plug is not it.
Old 05-09-2008, 05:59 PM
My mechanic found water and cleaned out around the spark plugs, and replaced the plugs. (info I just received) I wonder if the coil pack could have been affected?
Old 05-09-2008, 06:16 PM
ssbaudi's Avatar
how does it drive now? does it still misfire/skip/miss?
Old 05-09-2008, 07:20 PM
ericgl's Avatar
Modern engines depend so much on electronics to run correctly, its best to avoid power washing the engine compartment.
Old 05-11-2008, 04:30 PM
Still misfiring. I am a bit discouraged with the detail shop. I did not ask to have the engine washed.
Old 05-11-2008, 05:12 PM
Blue_S4's Avatar
take it to a dealer, have them look at it, its from water or soap....stick it on the detail place good!
Old 05-11-2008, 09:12 PM
Scott Long's Avatar
I'd have the coil pack checked out.
Old 07-07-2008, 06:49 PM
I had the coil pack replaced to on cylinder coil... it rips now thank you for the help
pgagnechat
08-19-2014 09:40 AM
mikk0090
09-02-2008 09:21 PM
suzanne86
05-01-2008 06:17 AM
bennettcorp5
04-22-2008 06:42 AM
dstehle
10-12-2006 05:39 PM
Quick Reply: Skipping or missing after an engine wash: S6 Wagon 1995.5
