Most of the 5 cylinder power steering pumps leak. it's probably coming from the cross plug on the top, right? you can buy a rebuild kit with new seals. replace the cross plug seal and you'll probably be fine. just be sure you hold your finger on it when you unscrew it (there is a spring underneath). the clutch sounds about right from my experience. bleed the brake lines after replacing your rotors and pads and enjoy your new car!
