We're adding and testing new features:  Create your Garage, used it? Give us some feedback here.
Go Back   AudiForums.com > Audi Models > Audi A8
Audi A8 This full sized Audi A8 sedan offers interior luxury and spaciousness comparable to any car in the full sized luxury sedan class
Welcome to Audi Forums!
Welcome to Audi Forums,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Reply
Old 09-24-2007, 10:03 AM
xx216xx xx216xx is offline
Default Another transmission problem thread
Alright, here's what happened...I had been driving down the highway for about an hour prior to this happening with no problems, but when I came to a complete stop at a traffic light and then accelerated, once the rpm's hit 1400 there was a loud thud and then my car went into limp mode. I pulled off to the side of the road and turned the car offand then back on and it was no longer in safe mode. So I pressed down on the gas pedal and I could feel that the car was in first because it started to slowly crawl but once again once the rpm's hit 1400 there was a loud thud and it went into safe mode again. It continues to do this unless I let the car gain a little speed (~5-7 mph) but then when I try to accelerate the car seems to be going into 3rd 4th and overdrive randomly as I press the gas pedal and after about 45 seconds of it going crazy it then goes into limp mode. My reverse works fine but everytime I hit 1400 rpm when first accelerating there is a loud thump and it goes limp. I got ahold of a guy with a vag com to pull some codes and reset them and this is what came up:
Original Codes ECU[/b]
Sunday,23,September,2007,20:12:09:01947
VAG-COM Version: Release 704.1
Address 01: Engine
Control Module Part Number: 4D0 907 557 D
Component and/or Version: 4.2L V8/4V MOTR AT D05
Software Coding: 01273
Work Shop Code: WSC 00214
9 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
18098 - Malfunction Indication Light (K83): Electrical Malfunction
P1690 - 35-00 - -
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16685 - Cylinder 1: Misfire Detected
P0301 - 35-10 - - - Intermittent
17546 - Fuel Trim: Bank 2 (Add): System too Lean
P1138 - 35-10 - - - Intermittent
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-00 - -
18032 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 35-00 - -
Readiness: N/A
Original Codes TCM[/b]
[/b]
Sunday,23,September,2007,20:13:33:01947
Address 02: Auto Trans
Control Module Part Number: 4D0 927 156 K
Component and/or Version: AG5 01L 4.2l4V USA D29
Software Coding: 00002
Work Shop Code: WSC 02314
5 Faults Found:
17090 - Transmission Range Sensor (F125): Implausible Signal
P0706 - 35-10 - - - Intermittent
17114 - Gear Ratio Monitoring: Incorrect Gear Ratio
P0730 - 35-00 - -
P0730 - 35-00 - -
P0730 - 35-00 - -
18169 - Shift Lock Solenoid (N110): Short to Ground
P1761 - 35-10 - - - Intermittent
Recurring ECU Codes:[/b]
Sunday,23,September,2007,20:20:48:01947
Address 01: Engine
1 Fault Found:
P1690 - 35-00 - -
Readiness: N/A
I'm hoping it's just something electricaland that seemsto bethe most plausible because the transmission will shift gear's if I get it up to speed but it seems to have trouble choosing a gear to go with. Any help would be great, thanks.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Audi Forums!
Old 11-16-2008, 02:33 PM
rbrito rbrito is offline
I got the some problem.
did you fix it?
how?
Old 12-22-2008, 07:57 AM
Keldo Keldo is offline
I have same problem... I was qouted $5000 by Audi to replace the TCM...
Control Module Part Number: 01J 927 156 CR
Component and/or Version: V30 01J 2.0l 5V RdW 2011
Software Coding: 00001
Work Shop Code: WSC 21000
1 Fault Found:
P0706 - 35-00 - -
Anyone knows how to fix these units ?
Old 10-21-2009, 01:54 PM
DamnA8 DamnA8 is offline
Would love an update on the limp mode thud problem you are having. My A8 is doing the same exact thing but only with slightly harder then normal braking.
Reply
Tags
01j, 125, 17090, a4, a6, a8, audi, code, f, f125, gear, implausible, incorrect, p0730, po730, ratio, transmission
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
