Audi A6The mid-sized Audi A6 model offers more room to the driver and passengers over the A4 line.
Engine missfiring, oil on spark plug electrode 99' A6 2.8L
Hi,
after getting a cylinder 3 missfire code I pulled the spark plug and the electrode end is COVERED in oil. This is the only spark plug that is oily. The car doesn't perform as it used to and my gas mileage is down. I did some research and what I understand is that it could be worn/broken piston rings or leaking valve seals is this right? Can I replace the valve seals without taking the engine apart or should I just sell the car? There are 91K miles on it. Thanks guys!
sounds like the valve cover gasket is bad. The gasket part around the spark plugs is letting oil into the spark plug chamber. Pretty common and just repaired myself.
But how would the oil get past the threads into the cylinder? The oil it on the electrode end of the spark plug.
Is it really oil? Did you check to see if your spark plug is working? How about your coil?
2001 A6 Avant
2.8 ATQ, Quattro, Tiptronic
Mods - Was chipped, but not now...
Repairs - Too many to list! And you wonder why I still drive an Audi
Do you mean into the combustion chamber? If you mean the cylinder where the the spark plug goes into, where the coil pack hooks up to the spark plug, then it would get in through the valve cover gasket around the spark plug cylinder.
If it'll help look at this link of a valve cover gasket and notice the inner gasket that seals the valve cover to the head around the spark plug cylinder.
