Reply
Old 04-07-2009, 03:55 PM
Midniteoyl's Avatar
Midniteoyl Midniteoyl is offline
1985 Dodge D-Series
My Garage
He means in the compustion chamber.. Needs to verify spark before doing anyhting else.
Jim
'96 A6Q - 140K already!!
  #12
Old 04-07-2009, 10:45 PM
lip lip is offline
I dropped it at the shop and was told the injector is bad, but somehow I don't see how this would cause oil buildup on the spark plug. So I took it back home and will try replacing the valve cover gasket next.
  #13
Old 04-09-2009, 04:47 PM
lip lip is offline
Default Update!
So I just found that the breather hose was split in two right below the cylinder shaped thingy that plugs into the suction pump. I wonder if that was the cause of my leaks due to pressure buildup. Replaced the entire breather hose with 3/4 heater hose as it had small cracks all over, but engine still misfires.
  #14
Old 04-09-2009, 05:16 PM
Midniteoyl's Avatar
1985 Dodge D-Series
My Garage
Very well could be part of the problem with the amount of oil you observed on the plug. With out the vaccum, pressure will push oil past the rings into the compustion chamber. Dont think it was the main cause, however. What was the result of the spark test?
Jim
  #15
Old 04-09-2009, 09:46 PM
lip lip is offline
Quote:
Spark is good.
  #16
Old 11-03-2009, 11:22 PM
indie.ianjones indie.ianjones is offline
1998 Audi A4
I'm having the exact same problem with my '98 A4 2.8, Took it to Audi and they replaced the seals on the cam tensioner and valve cover gasket, they also replaced the breather hose, it is still leaking oil into the cylinders and causing misfires. I read on another forum that it may be the piston rings have worn out. However, in the short term I'm using a fuel additive that raises the octane and cleans the combustion chambers so it only misfires when it's at a stop sign or stop light now (without the fuel additive it has RPM wavering and loss of power due to misfiring on almost all cylinders). Any other Ideas on this?
  #17
Old 11-04-2009, 12:16 AM
lip lip is offline
Quote:
It ended up being a bad fuel injector on one of the cylinders.
  #18
Old 11-04-2009, 02:16 PM
AUDIFIELD AUDIFIELD is offline
Default 98 a6 2.8 q
just pulled apart mine due to doing timing belt circus and decided to pull off and do the valve cover gaskes. had oil all over and in the same plug and it surley looks like the gasket was bad all around that area ........hope that helps.
RJF
  #19
Old 11-04-2009, 10:43 PM
a6hcw a6hcw is offline
The valve stem seals may be replaced without removing the cylinder heads by using compressed air through the sparkplug hole to keep the valves in place.
You could also get oil leaking in to the combustion chamber from a bad head gasket, a cracked cylinder head, etc.
A weak spark may cause the sparkplug to foul, so check your ignition.
A MSD multiple spark ignition may keep the plug from fouling, however it is rather expensive and may require special sparkplug wires and coils.
  #20
Old 11-05-2009, 12:34 PM
1998 Audi A4
the oil is pooling in the spark plug wells, could a bad spark or injector cause this?
Reply
Tags
28, 28l, a4, a6, audi, b5, chamber, combustion, diy, electrodes, oil, plug, plugs, spark, sparke
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
