FS: Forge 004 BOV
Old Apr 23, 2009 | 05:08 PM
tooxtreme8813's Avatar
Default FS: Forge 004 BOV
Up for sale is a slightly used forge 004 BOV, the color of the valve is blue. This is a dual piston BOV that stays closed at idle so it can be used on the 1.8T engine without any any ill effects. Using this BOV will not cause any CEL's so there is no need to worry. I'm looking to get $75 for this.
Old Apr 24, 2009 | 01:05 AM
bklynspapi88's Avatar
where are you located? and would i need any special adaptor for this to install onto my 1998 a4?
Old Apr 24, 2009 | 09:43 AM
i'm located in NJ, and no you do not need any special adapters to run this valve
Old Apr 27, 2009 | 01:37 AM
JPJ2007's Avatar
Still Have this valve?
So I'd be able to install, and open vent and not worry about any problems?
Wouldn't I run rich?
It's much louder than stock isn't it.
Old Apr 27, 2009 | 09:56 AM
yes this is still available.
yes you can use this valve on your car without any problems, the only time you would run rich is the split second you take your foot off the gas to shift.
the loudness depends on how much boost you are running
Old Apr 27, 2009 | 10:03 AM
b5audi1.8t's Avatar
Y does this one not have the return line back to intake do u just block that off then? and is 75 shipped?
Old Apr 28, 2009 | 09:39 AM
yes you just plug the line that runs back to the intake. I'll take $80 shipped to your door
Old Apr 29, 2009 | 08:35 PM
Sold!!
NuYorka103185
May 18, 2011 01:13 PM
vegastt
Sep 4, 2007 12:18 AM
blaznD
Jul 1, 2007 02:26 PM
.clipse
May 15, 2007 11:55 AM
dtmguy
Apr 16, 2007 03:24 PM
