Go Back   AudiForums.com > Audi Models > Classic Audi
Reply
Old 09-14-2009, 01:15 AM
mkppk mkppk is offline
Default How to know if Quattro is working? (1995 90)
I'm looking at buying a 1995 90 Quattro. The seller says "I'm not sure if the push button all wheel drive works".
What does this mean, is the car in AWD all the time, or is it possible a bad switch would cause it to be 2WD? Is there an easy way to verify if the car is working in AWD on a test drive?
I'm an audi newb, so any info about what to look out for would also be appreciated.
Old 09-14-2009, 04:54 PM
88A5TQ's Avatar
88A5TQ 88A5TQ is offline
Thumbs up if its a quattro...
its fulltime AWD. so he must be talking about the locking differential switch not engaging possibly. When you test drive the car turn on the locker switch from a standstill and slowly drive around a dry blacktop road corner and listen for the back axle tires to grip and slip on the pavement. The back axle is locked and the two wheels are traveling around a different radius on the turn so the tire on the inside back of the turn will do the slipping. Its pretty noticeable but its not like dukes of hazzard loud. Close all the windows except for the that tire's window and listen carefully for it. good luck
1988 Audi 5000CSTQ, Chip2.5cat-back(rally-esque beast tone)K&N CAI
1993 VW Passat GLX VR6...deceased -I miss the factory spoiler
Old 09-22-2009, 11:09 PM
Busabrye Busabrye is offline
Default all wheel
Go find some gravel and get nuts see what wheels are throwing stuff, I can feel the difference in mine thru the steering wheel, harder to turn locked up
Old 10-12-2009, 04:36 PM
ledzepp2994's Avatar
ledzepp2994 ledzepp2994 is offline
go try and get stuck if you can its not working if you cant its working
1983 5000TD -1987 4000cs Quattro - 1985 5000s -1987 5000 cs quattro turbo -1986 5000s Parts.
Old 10-17-2009, 12:19 AM
Belgarion Belgarion is offline
Send a message via AIM to Belgarion
PSH! Quattro does not get stuck sir. At least i've not had to use the locker to get out of anything. Also, the light should turn on once it locks.
Reply
Tags
1986, 5000cs, audi, quattro, turbo
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
