Reply
Old 10-23-2009, 12:20 PM
twinturbosixer twinturbosixer is offline
thank you so much for the help Bob.
Average time to complete?
Also, the bolt that goes into the axel, thats a one time torque bolt correct? How much do those cost to replace?
  #12
Old 10-23-2009, 12:30 PM
nvm, the bolt costs 19. unless I am able to order this part online. anyone know of a good site for this bolt?
  #13
Old 10-23-2009, 12:35 PM
Jackmup's Avatar
Jackmup Jackmup is offline
www.partsgeek.com
www.blauparts.com
www.ecstuning.com
www.autohausaz.com
02-A6 Quattro 3.0 Avant
00-A8 Quattro 4.2
  #14
Old 10-23-2009, 07:07 PM
bob martin bob martin is offline
The bolt should have come with the kit, BUT you can reuse yours. After all, they don't come with control arm or bearing kits...
While jackmup recommends going in via the top control arms, be aware that the upper control arm pinch bolt will often corrode into place requiring hours of frustration to drill out. Going via the bottom avoids this potential frustration. And, having done this job both ways, I recommend removing the axle and dealing with the CV joint removal on the bench. Perhaps I haven't learned the secret touch to getting the CV joint off while on the car, but I spent 4 hours on the bitch on the car and five minutes on the one off the car.
YRMV!
Good luck!
Bob
  #15
Old 10-23-2009, 11:17 PM
a6hcw a6hcw is offline
The CV joint kit should come with the new axle bolt, circlip, boot, two bands, grease and a few more parts. You will need to buy a CV joint band pliers.
Some of the boot kits do not have enough grease or parts.
The axle bolt should be loosened and tightened with the wheels on the ground, per Bentley.
The car should not be moved once the axle bolt is removed, per Bentley.
  #16
Old 10-24-2009, 01:10 AM
Jackmup's Avatar
I have heard those bolts are a bitch. So keep in mind I'm in Florida with two Florida cars. These cars have not experienced road salt. So all my bolts come right out. I just did my control arms and not one bolt was frozen. So if that is the case Bob's way might be the easier way. Your going to have to print this stuff out and figure out the best way when you get in there.
spray them down with Liquid wrench a week in advance.
00-A8 Quattro 4.2
  #17
Old 11-04-2009, 03:34 PM
zzr zzr is offline
How many flat-rate hours does an independent shop charge for 1 side front outer CV boot?
thanks
  #18
Old 11-05-2009, 09:20 AM
2.5 hours per the book. So at $75 an hour, $200 or so is a fair price.
Keep in mind those are after tax dollars. Depending on your tax bracket, you would need to earn $250 to $300 or more to pay someone else to do this repair. How long does it take you to earn this amount of money? Chances are you can "earn" this in less time (and "learn" something in the process) by doing the job yourself. And, Autozone and etc. all loan tools so there are very few you would actually need to buy.
Bob
Reply
Tags
17mm, 2000, a6, allen, alxe, audi, axle, bolt, cv, elantra, front, hyundai, joints, loosen, seperating, size, tt, wrench
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
