Reply
Old 10-28-2009, 11:38 PM
Acidic Acidic is offline
She will help, maybe with a little grumble but she is helpful and grateful. I had been contemplating a one person bleeder but it's just not worth the money right now... maybe next time around...
  #12
Old 10-29-2009, 01:53 PM
NH_USA NH_USA is offline
LOL I have a one person bleeder (pneumatically powered) but only use it as a jar to hold spent fluid because it is a PITA.
As for the little grumble-- That is normal after marriage.
Isn't it interesting how they go from I'll help you with anything. to You want me to do what?
1997 A6 Avant
1998 Jetta
2007 Dodge Grand Caravan SXT
one High Performance Roller Skate
  #13
Old 10-29-2009, 04:35 PM
r1racer r1racer is offline
Quote:
Originally Posted by NH_USA View Post
Any wife that is allowed to drive an Audi had better be willing to sit in the vehicle and pump the brakes while your bleeding them.
Make sure the master cylinder is full of fluid and have her press on the brake peddle. Open the bleed valve (with a small hose attached whose end is in a jar) and tell her to let you know when the peddle hits the floor, tell her to keep it pressed down. close the valve and tell her to pump the brakes a few times --Repeat this multiple times at each wheel making sure you refill the master cylinder.
If your wife isn't willing to help tell her that she will soon be driving a Yugo...and the cute blond at the office will be driving her Audi.
PS If you follow these instructions and she slaps you up-the-side-of-the-head Don't blame me --Your the one that married her! not me!
If you bleed the old fashioned way make sure you put a brick or two or something that will stop the brake pedal from flooring out. This can damage the seals in the master cylinder.
  #14
Old 10-30-2009, 10:42 PM
argg, the first caliper went fine then on the second one I stripped then broke off the nipple. So I guess I'll have a mechanic fix that and then finish the job. I suppose I should have him replace all of the nipples while he's at it.....
  #15
Old 10-31-2009, 12:46 AM
a6hcw a6hcw is offline
Just put a length of clear plastic flexable tubing on to the bleed screw nipple and put the other end in to a clear glass jar with a hole in the lid. Add a small amount of old brake fluid to the jar with the end of the plastic tube at the bottom. Locate the jar above the brake caliper and then open the bleeding screw and begin bleeding. When done bleeding, close the bleeding screw before removing the plastic tube.
  #16
Old 11-02-2009, 01:45 PM
Don't tell your wife that your replacing nipples!!
1997 A6 Avant
1998 Jetta
  #17
Old 11-05-2009, 07:58 AM
haha... yah I don't want her to get jealous
Reply
Tags
1997, a6, audi, bleed, bleeding, brake, brakes, caravan, changing, dodge, forum, master, pads, spongy, weak
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
