Go Back   AudiForums.com > Audi Models > S Car Model Line
Reply
Old 10-28-2009, 07:18 PM
Audi_Skydiver's Avatar
Audi_Skydiver Audi_Skydiver is offline
Default Weird Problem With My Tune....
Well I have a GIAC X tune in the car and I have had low boost numbers for a while so I decided to log it using vag-com and have some interesting findings... I have a lot of info that I logged so i put it all in an file for you guys to look at.
http://www.jmlpictures.com/jmldownlo...reTest_Log.xls
There is a graph also of the requested vs actual boost. Any ideas?
Josh
www.JMLPictures.com
All You Need To Know About Digital Photography Thread!
http://audiforums.com/forum/showthread.php?t=103131
Old 10-28-2009, 08:25 PM
Mott Power Mott Power is offline
Send a message via AIM to Mott Power
The turbos aren't on there way out are they? If not, I would imagine a boost leak. But what's up with the sudden in drop? Odd because it shows up on the Requested and Actual.
"Great folks gathered at the festival of Golthar. One being Rizaru, Chieftain of the far lands. During his high rein, he was capable of dismounting a soldier off his stable from one hundred yards away using a mere toothpick and his penis."
Old 10-28-2009, 09:41 PM
The car started to feel like it was missfiring so i let off the gas for a sec and then it went away.... No codes of missfires or anything either.
Josh
www.JMLPictures.com
Old 10-28-2009, 10:36 PM
Oh ok, I was all 'wtf?!"
Well if you're turbos were making that low of boost I would imagine they'd be whining like mad. I would still say a boost leak, obvious things like leaky DV's and tears in the rubber/ silicone parts. Could be a faulty N75 valve even.
Old 11-03-2009, 12:33 AM
Ok, so I replaced my drivers side O2 which was bad (and it wasnt nearly as hard as I thought it would be! but i just went for a test drive and im still having a weird problem. Whenever I shift from 2nd to 3rd the car just doesn't want to go anymore. My boost gauge is says it's at 7-8psi but the car just doesn't go... it starts, for a lack of a better word, jerking/hesitating instead of accelerating. If I start from a 25-30mph roll in 3rd gear and just punch it the car accelerates well without any weird jerking/hesitating problems. Just still under-boost. I still think it could possibly be a boost leak but can a boost leak cause those problems too?
Also I just pulled these codes for the first time. Im hoping that the System To Rich is due to the O2 sensor being bad. I will see if that comes back now that it's replaced:
17964 - Charge Pressure Control: Negative Deviation
P1556 - 35-10 - - - Intermittent
17535 - Fuel Trim: Bank 1 (Mult): System too Rich
P1127 - 35-10 - - - Intermittent
17537 - Fuel Trim: Bank 2 (Mult): System too Rich
P1129 - 35-10 - - - Intermittent
P1127 - 35-00 - -
Any ideas? Bad N75 causing all these problems???
Josh
www.JMLPictures.com
Old 11-03-2009, 12:32 PM
AutoUnionFan's Avatar
AutoUnionFan AutoUnionFan is offline
check for boost leaks before replacing valves
2001 A4qm 1.8T : spt pkg : xenon : light mods < GIAC flashed / N75J / K&N drop in / A8 bbk / JHM ssts >
Old 11-03-2009, 05:39 PM
Yeah im going to do that today.
Josh
www.JMLPictures.com
Old 11-03-2009, 07:17 PM
Well found my boost leak!
Time for a new TBB!
josh
www.JMLPictures.com
Old 11-03-2009, 07:48 PM
Just ordered the Samco TBB. Should be here in 3-4 days... I WANT IT SOONER!
josh
www.JMLPictures.com
Old 11-04-2009, 01:02 AM
So i did a temp fix on the old TBB just till my new one shows up. I wrapped the part that was torn in electrical tape to try and seal it really well and put it all back together then re-pressure tested. Didn't hear any leaks so I went for a quick drive and EVERYTHING IS WORKING RIGHT! My boost is right where it should be. No more crappy shifts where it falls on it's face, and it just sounds better. Amazing what that boost leak will do to your car! HAHA. Can't wait to get the SAMCO TBB and have this problem fixed for good!
Josh
www.JMLPictures.com
Reply
Tags
2001, audi, boost, deviation, intermittent, low, s4
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
