Audi A6The mid-sized Audi A6 model offers more room to the driver and passengers over the A4 line.
both! how do i get the fan off? the four bolts wont go anywhere no matter how hard I try and I dont wanna ruin the thread and the big nut in the back just turns and turns and nothing happens. I cant figure out how to remove it.
Don't You Just Love The Sound of Turbos In The Morning?
The chop stick tool that you are referring to is called an adjustable spanner. I guess you can vice grip the shaft and turn the reverse nut with a wrench, but I am not sure whether there is enough clearance for a vice grip. You can buy one cheap especially online.
2001 A6 Avant
2.8 ATQ, Quattro, Tiptronic
Mods - Was chipped, but not now...
Repairs - Too many to list! And you wonder why I still drive an Audi
ugh this is pissnig me off. ill try my best thanks. oh and i have another stupid question. I accidentally turned the harmonic balancer and everything moved and i got scared and moved it back. will this mess anything up?
I loosen the fan bolt as follows: With the serpentine belt still in place to put friction on the fan, place the spanner on the fan bolt and give the spanner a slight blow (clock wise) with a hammer. The "shock" usually loosens the fan quite easily.
the 4 bolts for the fan weren't too bad for me, so i didn't have to try to loosen the back nut with it on. with it off i stuck a 3 or 4mm allen key in one of the slots so it would get stuck while turning. Then i used a big adjustable wrench to loosen. (you are aware that you loosen the back nut turning clockwise right?)
yes i know it has a reverse thread. but nothing is still working for me. the allen bolts must be really tight because im practically ruining the thread. i put wd40 on it to try and loosen it and get it a little lubed but still nothing. i also broke something inside that (pulley) is it? i stuck a screw driver through the fan holes into the thing behing it and some peices of metal broke off inside and fell down. idk. ughh!
