misfiring problems any help out there?
Old May 23, 2006 | 01:07 PM
shufti's Avatar
Default misfiring problems any help out there?
hi guys
i own a 2000 a6 avant 1.8T which has devoloped a misfiring fault. it generally drives on average at 30mph max with my foot to the floor with intermittent bursts of power that last no more than a couple of seconds.
can anyone help me in locating the problem, i can't afford to give it to audi so will try and replace the relevant parts myself once i know what is causing the problem.....
i've had suggestions of the maf filter or coil packs that could be causing this but these were suggested before i done the scan... i was able to arrange a vag-com scan today and this is what come back........
vag com - faults found......
17544 - Fuel Trim: bank 1 (add) system too rich - P1136
17536 - Fuel Trim: bank 1 (mult) system too lean - P1128
16684 - random/multiple cylinder misfirwe detected - P0300
16685 - cylinder 1 misfire detected - P0301
16687 - cylinder 3 misfire detected - P0303
16688 - cylinder 4 misfire detected - P0304
16686 - cylinder 2 misfire detected - P0302
17925 - main relay (j271) electrical malfunction - P1517
18010 - Power Supply Terminal 30: voltage too low - P1602
18034 - Power train Data Bus: missing message from TCU - P1626
17834 - EVAP Purge Valve (n80) open circuit - P1426
i called audi with the details of the main relay fault (17925 - main relay (j271) electrical malfunction - P1517) i thought that replacing this would be as good a place to start but after calling 3 dealers nobody could tell me what relay this is! anyone out there know????
thanks
Old May 23, 2006 | 01:20 PM
techbod's Avatar
Default RE: misfiring problems any help out there?
the relay is under the hood there are 3 relays and 6 fuses 2 ate the top and the other 4 at the bottom relay 3 is your counting from left to right, I also agree this is probably the problem for all the other codes as I have checked through my data
Old May 23, 2006 | 01:38 PM
shufti's Avatar
wow that reply was quick! thanks!!!!!
i will be so happy if a relay replacement sorts this, i've just been told it could be the ecu!
where abouts under the hood on a 1.8t should i be looking for the relay?
there is nothing obvious when i lift the hood?
thanks
Old May 23, 2006 | 01:40 PM
techbod's Avatar
left hand drive its passenger side below the windshield
Old May 23, 2006 | 01:44 PM
techbod's Avatar
there are 3 configurations the plate has for different models all the relays for the engine side is the right hand side of the plate
Old May 23, 2006 | 02:00 PM
shufti's Avatar
my a6 is right hand drive (i'm in the UK!)
i still can't see nothing obvious near the windshield! could it be in the same box as the ecu?
i have read somewhere that it is possible vag-com can find this relay in an engine that may not even be in that model of car, could this be the case?
i tried to copy and paste a picture of my engine bay on the forum for a guide but was unable to.
thanks again for the amazingly quick response!!!!!!
Old May 23, 2006 | 02:04 PM
techbod's Avatar
its to the left of the battery near the inner wing driver side for the UK
Old May 23, 2006 | 02:09 PM
shufti's Avatar
my battery is nearer the centre of the car but towards the passenger side,
on the drivers side nearest the inner wing is the ecu box
Old May 23, 2006 | 02:11 PM
techbod's Avatar
well its got to be in there mate
Old May 23, 2006 | 02:15 PM
shufti's Avatar
as soon as it stops raining i'm out there with my toolbox!
i'll post up what i find, hopefully 3 relays and 6 fuses...........
thanks for your help
