New A6 recall
Old Nov 20, 2004 | 04:23 PM
Ted's Avatar
Ted
Default New A6 recall
There is a new recall for the older A6. It is to replace the throttle body again. It dose not apply to all of them, only the 2.8L in the "cold wether zones" All it dose is replace the old one with a updated throttle body with a internall engine coolent line. It is to make shure that the throttle flap dose not stick. From what i heard some one in some far off place almost had this problem. But since Audi is **** retentive, there is now a recall. Just to let you know.
Old Nov 20, 2004 | 09:18 PM
SlimChriz's Avatar
Default RE: New A6 recall
Car makers dont issue recalls for onetime problems they have a general rule about cost VS. liability.
Old Nov 20, 2004 | 10:13 PM
Jestnomen's Avatar
6th Gear
Wait a minute, they would have to replace the intake manifold if they wanted to run coolent through the throttle body. What is your source for this recall?
Old Nov 23, 2004 | 08:38 PM
Ted's Avatar
Ted
Yes Slim the problem proly has come up a few times. Audi not THAT bad. Jestnomen, I am a tech for a dealer, and have done about 4 JB recalls on the 2.8 a6's. There is a hard pipe coolent line that runs under the throttle body, it has two nipples that you take the old hose off that used to run snug with the t/b to heat it, but now when you replace the t/b with the new one there are ports in the bottem of it that you connect them to. nothing big. takes about a 1 1/2 hour.
Old Nov 23, 2004 | 09:19 PM
Jestnomen's Avatar
6th Gear
ahhhh thanks for the info ted.
Old Nov 25, 2004 | 09:42 PM
Ted's Avatar
Ted
Glad I could help
Old Dec 1, 2004 | 04:04 PM
norcaltrojan's Avatar
Recalls are overrated. Just keep drivin and ignore the problem.....that usually seems to work pretty well, but for some reason the cars don't last as long.....hmmmmm.......oh well [8D]
Old Dec 9, 2004 | 06:45 PM
clconversion's Avatar
Hey Ted you have only done 4 of these or was this post at the beginning of the recall cause we have done like 30 now
Old Dec 12, 2004 | 01:57 PM
Ted's Avatar
Ted
Clconversion, Yea i have done alot more now, they keep coming and coming, never knew that there was that many of the buggers out there.
Old Dec 12, 2004 | 08:53 PM
audifan's Avatar
Ted and others, I was searching for recall notices here....found this one.. but I have problem with front suspension in my 2000 A6 Avant. As there any recall about this. I am a new member and just posted longer description of this problem in new member section- if you dont't mind please check quickly there..
Thanks Pete
