Reply
Old 01-06-2005, 01:41 AM
ZinC4 ZinC4 is offline
Default A4 Ashtray
The front ashtray on my 2000 A4 1.8T auto will not open unless pried. It then closes easily. Can someone give me the basics of removing the ashtray so I can see if something is stuck behind it or if a gear is broken?
Old 01-06-2005, 01:45 AM
Jestnomen Jestnomen is offline
Send a message via AIM to Jestnomen Send a message via Yahoo to Jestnomen
Default RE: A4 Ashtray
do you store change in it?
2005 A4 1.8tqm Avant
2004 VW Touareg
2005.5 Audi A4
Old 01-06-2005, 01:53 AM
jason745 jason745 is offline
just out of curiousity, is it bad to store change in it?
I sometimes drop change in mine.
Old 01-06-2005, 01:56 AM
Yeah, #1 Cause of jammed ashtray.
ZinC4, have you tried prying it out with a screwdriver carefully?
2004 VW Touareg
2005.5 Audi A4
Old 01-06-2005, 11:58 AM
kraller kraller is offline
yeah mine does the same thing, I havnt had a chance to get mine out yet and check but i know storing change in them is not the best idea beacuse mine has a penny stuck behind it making it even harder to close.
Old 01-06-2005, 11:19 PM
I do store change in it. But, I can pry it open with a screwdriver. It then closes gently, but will not open with a push, as before. I assume that once I remove the ashtray, I will be able to remove whatever is blocking it.
Old 01-06-2005, 11:26 PM
If it is anything like the older style ash tray, there should be two holes you can stick a screw driver down into. There are little metal prongs you have to push on. the ash tray should wiggle out as soon as you get them both pressed down.
2004 VW Touareg
2005.5 Audi A4
Old 01-13-2005, 02:29 PM
hoonee46 hoonee46 is offline
also, if you've taken it out before.... or you do now cuz it's jammed, don't forget to wind the little gears up a bit before you put the ashtray in again... or else it won't have enough strength to push the ashtray back out. fixed mine yesterday
'96 A4QM 2.8L 12v
Privat 17X8 + 235/45et35
'99 Sports Suspension
VIS CFHood, Clear Projectors, smoked tails + side markers
10" AlpineS w/ Custom box, RF Amp
soon to come: headerback 1HFC exhaust
Old 09-19-2009, 05:04 PM
B6 Cabrio B6 Cabrio is offline
I know there is change stuck behind by ashtray (I assume it slid behind down from the top of the little door when it was opened). So I pulled up the plastic trim around the gear selector and took out the two screws holding the ashtray. After trying for an hour to take the ashtray out completly to un-jam the coins, I gave up and tried to put it back in. But I can't quite get it to be flush the way it used to be. Any suggestions? I don't want to remove the A/C head unit unless I have to.
Old 10-09-2009, 06:51 PM
jsckpc jsckpc is offline
I had the same problem with replacing the ashtray. I just figured this out. I pulled out the bottom of the AC unit about an inch. Then I slid the ashtray underneath the AC unit and then pushed/tilted up the back of the ashtray. It was like fitting the ashtray underneath the AC unit. The ashtray sat in place, flush. Once flush I could push the AC unit back into place.
Reply
Tags
03, 2000, 2003, 2006, a4, ash, ashtray, audi, b5, jammed, removal, remove, removing, replace, stuck, tray
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
