Reply
Old 10-17-2009, 04:53 PM
tonytee tonytee is offline
Default radio
i just changed my battery and my radio is in lock-up but i dont have the radio card can i reset it myself
  #122
Old 10-17-2009, 10:43 PM
chefro's Avatar
chefro chefro is online now
1995 Audi A6
if you have an Audi Gamma try : 0292
Otherwise contact an Audi dealer.
'95 A6 12V - 157,940 miles--
________________________________________
2000 Hyundai Elantra SW - 93,609 miles--
  #123
Old 10-18-2009, 03:24 PM
Default Stereo code
thanks
  #124
Old 10-19-2009, 10:21 PM
awelton515's Avatar
awelton515 awelton515 is offline
Yes I bought a 2001 a6 2.7t quattro and i am looking into putting a staggered 18 or 19 in wheel package on it. I know nothing about wheels and am new to this site so im just gonna post this here. I live in MN, where winter is approaching. What damage will winter have on hyper black wheels? should i wait till springt time?here are the rims http://www.myhotaudi.com/audi/Custom...Package/546888
  #125
Old 11-10-2009, 04:31 AM
lovely09 lovely09 is offline
Banned
Additionally,most common problems it may encounter.
1.Throttle body boot (TBB) Failure is a small rubber boot that connects the two pipes that deliver air from the intercoolers to the throttle body.It is shaped like a truncated “Y” and frequently tears due to overtight clamps or simply a defective design (poor material).
2.Bypass valve failure-Instead of using Blow Off Valves like many turbo cars, the S4 uses Diverter Valves or bypass valves.There are two DVs (one for each turbo) that frequently fail because of a poor design by the manufacturer.
3.F-Hose is a little hose shaped like an “F” and is made of rubber.It is prone to tearing.
  #126
Old 11-14-2009, 03:25 PM
powerstar powerstar is offline
Quote:
Originally Posted by twinturbomew View Post
things you should look into first.
quick refrence
any car with or around 60K
1 timingbelt replacement at 60K & 120K
2 front suspention tie rods control arms
3 check o2's they tend to start going bad and can effect performance
4 year 2000/2001 if you have a bosh MAF check and replace if needed. they start going bad but don't always fail. they just start reading wrong.
any car with 85+
1 check all above
2 replace fuel filter
3 check all vac hoses (this Is best done with prusure tester
4 check around the turbos around tis milage turbs seem to start to show sings of failure
5 check your temp sender and make sure you have a green one that is the up dated one
this is a little more info about some of the above
Dose your car have a new timing belt?
this is one of the things that will destroy your motor if not checked. if the timing belt snaps you will do major damage to your motor
Your stock turbos will blow sooner or later. it is more of a matter of when not if
stock turbo is a Ko3
Ko4's are the replacment turbos they come from the RS4.
there are only 2 off the shelf turbos for the 2.7t that are OEM they are the 2 listed above
there are hybrid turbos available. a ko3 hybris is abviously not going to be as big as a ko4 hybrid
a chip is not going to make them blow but it isn't going to help.
A great way to extend the turbo life is to get Dp's. they will drop the exhaust temperature by 200 degs in some cases. not only that but they will alow the turbos to have less restriction and thus no work as hard to produce as much boost.
There is no reason not to get Dp's VAST performance sells tip and 6 speed Dp's for 400$
Also turn the boost down in the winter (if you have a MBC) or just completely disconect the turbos from the N75 and have them make less boost
chips
chipping you car will be the best bang for you buck.
All chips increase boost to about the same levels. the only difference is the timing.
So don't believe that one chip over another will blow your turbos
the best chips are from the 3 companys that have been around from day one.
APR great chip smooth and fast
GIAC very aggressive on the timing and alows you to expand to a mbc and other mods without any adjustments
MTM this is a great file they fall in between the other 2 options. Don't seem to be as popular only due to not vary many distribution states
I IMHO would not sugest getting a chip from anyone else
O2 sensors can go bad and so can the 2000/2001 bosh MAF check both every other oil change. if either are bad they will cause the car to run improper
Also check you deverter valves up grades are the 710N DV from the audi tt
get a prusure tester for you car and sest the system Twice a year this will tell you if you have any boost leaks
Get a vag com from ros-tec it is the best way to check codes and monitor the car
Thank you for the info
Reply
Tags
27t, 5w30, a6, audi, chip, difference, forums, oil, performance, s4, timing, tip, turbos, type, vast
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
