Transmission Help - 1999 A6
Old Feb 3, 2005 | 08:33 PM
Badgerheel's Avatar
Default Transmission Help - 1999 A6
I have read through the board and several people seem to comment on Transmission problems. I have a 1999 A6 Quattro (has 60k miles) and my wife has noticed that when the car is cold it has difficulty shifting through certain gears. She took the car to the Audi dealer who said that the oil was extremely burned and the transmission needed replacing for an astronomical fee. I took it to an independent transmission repair should who said the car had an internal transmission issue, but due to a number of issues I felt he was not trustworthy, so I took it for a third opinion. The third place indicated that he could not find anything wrong with the car and also took it to another repair shop down the street who said there appeared to be no problem. I have a hard time deciding what to believe. I know that these cars have problems historically with trannys, so I was wondering if any of you have experienced anything like this or have any advice on diagnosis. Thanks for your insight.
Old Feb 4, 2005 | 02:17 AM
Jestnomen's Avatar
6th Gear
Default RE: Transmission Help - 1999 A6
My car has difficulty shifting when it is cold too. Notably into to third gear. I've just come to accept it. I changed the snub mount and tranny fluid, which made a noticeable difference.
Old Feb 11, 2005 | 01:32 AM
chuckie_mn's Avatar
I had test drove about 6 cars before mine all ranging from 98-00 and 20K to 111K at some point they all did what you describ. My 98 has 142000 and does it sometimes and sometimes in the morning (if is cold) it seems like it take a few to shift out of first. Maybe just taking the steps from Badgerheel to improve the performance would help. But i would not sweat it to much.
Old Feb 27, 2005 | 06:00 PM
tripod's Avatar
My understanding is that the tranmission will hold lower gears longer than ususal until full engine temp is obtained, this is supposed to speed up warm-up and aid emmissions. My car has always shifted later in the cold
Old Mar 3, 2005 | 06:13 PM
siddiqui2000's Avatar
There is a delayed shift in gear changes when the car is cold. This is a desired feature designed to raise the temperature of the catalytic converter as soon as possible to burn the remaining fuel vapours. The gears hsould shift fine once the car gets warmed up after 2-3 minutes od driving.
Old Mar 4, 2005 | 12:59 PM
clconversion's Avatar
If you are really unsure take it to a transmission specialty shop
Old Jul 24, 2006 | 01:13 AM
djcleve's Avatar
Hey all... I too have a 1999 A6 and I wanted to know if any of you know how to add transmission fluid to the vehicle. I was changing the oil today and accidentely drained the transmission instead of the oil but can't figure out where to add. Can anyone help? Please let me know!
Cleve
djcleve's Avatar
Cleve
Old Jul 24, 2006 | 01:22 AM
Cameron's Avatar
I did a right up on this actually a bit ago. I learned this at work.
https://www.audiforums.com/m_309195/.../tm.htm#309195
Old Jul 24, 2006 | 01:54 PM
Scotts's Avatar
So the car needs to be up on 4 jack stands and the tires need to be spinning to go into each gear, right?
I guess that's obvious, but I didn't read that part anywhere. I'll be changing the fluid and filter next weekend.
