transmission final drive seal
Old Apr 2, 2007 | 09:06 PM
wings7351's Avatar
Default transmission final drive seal
anybody knows about the transmission final drive seal? and what if it fails? how do i check it?
Old Apr 3, 2007 | 01:48 AM
Bravoo67's Avatar
Default RE: transmission final drive seal
Final drive out shaft seal?? If there is something wrong with seal you can easy figure it out by checking if tehres any oil under ur car after its been parked a while, usually u can notice smell of burning oil too when the car is warm(hot), its because oil is dropping on exhaiust pipes/catalytic converter. I paid for seal around $36 at the dealership,and $30 for audi manual transmission fluid 1qu + $36 for 2 brackets u might need to replace while disconnecting exhaust pipes. Dont know how much does it cost to replaceseal thought, but if u get any quotes post them on forum please gl
Old Apr 4, 2007 | 04:32 PM
wings7351's Avatar
Thanks, what if I don't fix it?
Old Apr 4, 2007 | 07:07 PM
wings7351's Avatar
would that cause my gas usage going higher?
Old Apr 11, 2007 | 06:03 PM
mustang196718's Avatar
ORIGINAL: wings7351
i highly doubt that, all the seal does is just keep tranny fluid from leaking out from the tail of the transmission.
Old Apr 11, 2007 | 06:21 PM
smtcapecod's Avatar
less fluid= more friction= more heat yikes.
My car's service records showed several replacements of the seal. Bolts can't be reused according to dealer, FYI.
Old May 7, 2007 | 01:52 AM
wings7351's Avatar
Bravoo67, is the oil dripping betwen the two pipes behind the transmission? I suppose it is not directly under the transmission. I just changed the ATF and hope it is not because the gasket was not done right when they put it back. Thanks.
Old May 9, 2007 | 10:15 AM
mcicoria's Avatar
FWIW, I'm having the same problem with my 99 2.8 wagon. The local shop that only works on Audi/VWs recommended keeping an eye on it but not to replace it as the fluid loss is minimal. They also said that these seals drip frequently, even after being replaced.
GregL
Aug 27, 2010 11:14 PM
cnterline
Jul 5, 2009 10:46 AM
PhatPipe
Nov 9, 2007 11:58 AM
fedir
Feb 25, 2007 02:33 AM
plumbous
Nov 21, 2005 04:59 PM
