Reply
Old 06-16-2007, 02:32 PM
onepoint8tee's Avatar
onepoint8tee onepoint8tee is offline
Send a message via AIM to onepoint8tee
Default READ THIS IF YOU HAVE A CHECK ENGINE LIGHT!
Go to Autozone and get your ECU scanned for the fault codes, record them, and post them in a new thread. This will eliminate the "I have a CEL and dont know why" type threads.
Good investments:
www.ross-tech.com(Vag Com diagnostic software)
http://stores.ebay.com/mechanic-doctorMD(Generic code reader)
Anyone can guess as to why you have a CEL, but you MUST have the fault codes retrieved from the ECU with a scan tool or laptop diagnostic software like Vag Com to pinpoint the cause or put you in the right direction. Any OBDII scan tool will work. TheOBD portis under the dash on the drivers side, and in some cases in the back seat ash tray.
ALSO!
If your CEL is flashing, that indicates a misfire. Get your ECU scanned. It should tell you which cylinder is misfiring. Take the coil pack from that cylinder and swap it with a different cylinder. Drive. Rescan for fault codes. If the misfire followed the coil pack you moved, you can be sure that its a bad coil pack.
If you have a 97-99 1.8t and the above method didnt resolve your issue, you likely have a bad ICM (ignition control module) or "ignition amplifier." Its located on top of the air box. They can be found on ebay for pretty cheap compared to what the dealer charges for the OEM bosch unit, and are equally, if not more reliable.
Those are the 2 most common causes for misfires.
Note: Cylinder #1 is closest to the radiator, and cylinder #4 is closest to the firewall. This should make finding cylinder's 2 and 3 self explanatory
Im not sure about the cyl. order on 2.8/3.0, etc. But Im sure its similar with 1 and 4 being the closest to the radiator.
Old 07-28-2009, 03:11 PM
kanickle88 kanickle88 is offline
Default 97 audi a4 check engine/misfire
Would it be safe to drive the car to the auto parts store to get that checked out?
97 Audi A4 1.8 Quattro
Old 07-28-2009, 08:51 PM
R3V3NANT's Avatar
R3V3NANT R3V3NANT is offline
Send a message via AIM to R3V3NANT
Yeah, you can drive it to the store. If it's misfiring, it won't help fuel economy or run as well as it should, but it shouldn't hurt anything to go get it checked.
Old 08-04-2009, 12:32 AM
so this was a really good place to start and was so helpful. I think that we figured out the problem of the car and it was all thanks to this
Old 09-09-2009, 11:16 PM
SincereOne12 SincereOne12 is offline
Default Misfiring flashing check engine light
I would not suggest driving your car too far if you're check engine light is flashing because of a misfire. Your fuel will eat the hell out of your catalytic converter and your 100 ignition coil and whatever else you spend on coils will end up running you $4000 on a new cat. So watch it.
Old 09-25-2009, 06:22 AM
kurtdaniel kurtdaniel is offline
Quote:
yeah..better tow the car..
Reply
Tags
1, a4, audi, cel, check, codes, cylinder, engine, firewall, flashes, flashing, issue, light, ligth, selfread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
