Go Back   AudiForums.com > Audi Models > S Car Model Line
Reply
Old 11-15-2007, 02:56 PM
aLifeQuixotic aLifeQuixotic is offline
Default E85 in the 2.7t
What the consenus on running E85 in the 2.7t?
It's a higher octane, so it wouldn't hurt to switch the car over to it, would it?
I'm formulating how I want to build my car, and am now considering the engine build being E85 centric.
-Brian
Old 11-15-2007, 04:28 PM
2k S4 2k S4 is offline
Default RE: E85 in the 2.7t
You should be ok, it is higher octane, but lower thermal reactivity, so less power. If you are going to run it a lot, & drive the car hard, I would Lemi it & add 5% more fuel.
If you PM me waning help, PayPal $5 to evoiiim3@yahoo.com first!
2005 Lighting Yellow Lancer EVO 8
2000 Audi S4 Imola Yellow
1997 Porsche 911 C4S, Black
Old 11-15-2007, 04:29 PM
Fier Ringe Fier Ringe is offline
Good luck with that. You need to research how turbochargers are effected by E85.
For OE parts and performance parts check out www.avalonmotorsports.com
Old 11-15-2007, 05:12 PM
Flip Flip is offline
Send a message via AIM to Flip
It's a higher octane so turbochargers react well to it. Less knock ftw!
2005 Audi A4 3.0 Quattro S-Line 6 Speed - RS4 Clutch, AWE Lightweight Aluminum Flywheel, HID E-Codes, Magnaflow 14851 Mufflers, S4 Rear Bumper, S4 Door Blades, Caractere Front Bumper, Caractere Grille, Caractere Roof Spoiler, Boser Hood, S4 Mirror Covers, VMR V710 Wheels, 28% Window Tint, Koni Adjustable Shocks, Neuspeed Race Springs, S4 Recaros F+R
Old 11-15-2007, 05:16 PM
turbo kraut's Avatar
turbo kraut turbo kraut is offline
e85 would not be good in your turbo motor, becuase of this statement
The horsepower a given engine has when using E85 is comparable (or slightly higher in some instances) to gasoline. Depending on composition and source, E85 has an octane rating of 100 to 105 [3] compared to regular gasoline's typical rating of 87 for regular and 93 for premium. This allows it to be used in higher compression engines, which can lower emissions.
E85 gets approximately 25% fewer miles per gallon. In order to save money at the pump the price differentiation between gasoline and e85 would need to exceed 25%. Currently E85 is about 5-10% less expensive in most areas.[4] More than 20 fueling stations across the Midwest are selling e85 25%-40% cheaper than gasoline.[5]
01 A4 1.8tqms: apr | s4 | rs4 | stratosphere | clutch masters | euro |a8 | TT |
B5 Battalion
Need extra income?? Email jrhoads63139@gmail.com to find out how.
Old 11-15-2007, 06:33 PM
1972beast 1972beast is offline
We run bio diesel in one of our company trucks and its always in the shop with some sort of problem. I dont think its worth it until the motor is 100% only bio not both. And me being in MT its really really hard to find E85 or bio.
1972 Sububan 400hp
S6 Avant
Old 11-15-2007, 09:25 PM
smdrcr_9 smdrcr_9 is offline
no you cannot .. you need to compensate and run 30% more fuel at all times no matter what so you have to tune your ecu for it . yes it allows for more hp b/c of the higher octane but u have to compensate the fuel or u will kill ur car
Old 11-15-2007, 09:41 PM
Superdug's Avatar
Superdug Superdug is offline
SoCal Crew Member/White Devil
2001 Audi S4
Send a message via Yahoo to Superdug
E85 is Ethanol right? at 85%? I have run straight methanol in my car before and that shit is fun as hell. i lags below 2000 rpm because the jets aren't big enough but once you get going it's a whole nother animal. and it is very cold so it keeps the motor cooler as well..
Zombie Defense Force
Quote:
Originally Posted by kriptonik View Post
Doug - Why are you so baller?
Old 11-15-2007, 10:15 PM
E85 is an alcohol fuel mixture that typically contains a mixture of up to 85% denatured fuel ethanol and gasoline or other hydrocarbon by volume. On an undenatured basis, the ethanol component ranges from 70% to 83%. E85 as a fuel is widely used in Sweden and is becoming increasingly common in the United States, mainly in the Midwest where corn is a major crop and is the primary source material for ethanol fuel production; however as yet, there are still only about 800 filling stations selling E85 to the public in the US, and only one in Canada
B5 Battalion
Old 11-19-2007, 09:46 AM
Burzum Burzum is offline
E85 is also more corrosive than Gasoline. I think there is a reason that manufactures specifically say a car is E85 compatible. I wouldn't risk it in my S4 especially with the stock MAF.
If everything seems under control, you're not going fast enough - Mario Andretti
Stage I B5 S4 gone but not forgotten
Current ride: Chevy Colorado Z71 4x4 "Are you sure you're pushing the skinny pedal?"
Reply
Tags
2005, 27, 27t, 93, audi, awe, e85, ethanol, fuel, mixing, octane, rs6, s4, tt, turbo
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
