Audi A4The Audi A4 model offers nimble handling and performance that makes it one of the leading cars in its class. Read more about the Audi A4 in the Audi A4 review.
Ok so i am going to buy Blind Spot Mirror Glass for my B5. I just wanted to know:
1 can i remove the glass that is there and replace it?
2. If you can does anyone know how to remove the glass?
thanks a lot. im going to be getting this today or tomorrow so your help would be great
here is a picture of it, i have been waitting to find this for a very long time and hopefully its easy to replace the old glss with the new
01 A4 1.8t sport
Borla cat back exhaust with DP
Baliey's DV
Carbino intake
AWE DTS
APR 1.Bar
LL Tek Cross Tower Suspension Brace
Waiting to install: JHM
Rear-view mirror[/align]Removing and installing rear-view mirror[/align]
Mirror housing
â—†Can be removed from door without dismantling entire rear-view mirror Mirror adjuster unit [/ul]
â—†Remove mirror from door before removing adjuster unit. [/ul]
‒To remove, lever off mirror glass, unplug electrical connectors for mirror heater, unscrew cross-head bolts -6- and take mirror adjuster unit out of mirror housing -1-. [/ul][/ul]
Note:
â—†On vehicles with a seat memory, the door trim has to be removed before removing the mirror adjuster unit. [/ul]
Door subframe
Hexagon socket-head bolt
â—†12 Nm [/ul]
Seal
â—†When installing, make sure seal is seated correctly. [/ul]
Cross-head screw
â—†1 Nm [/ul]
Mirror glass
‒Use special tool 80-200 (assembly lever) to unclip mirror glass.
‒Protect top and bottom of mirror housing from damage with fabric-backed adhesive tape.
‒Lever off mirror glass at the bottom first, then at the top. [/ul][/ul]
‒To install, enter mirror glass into guide stud and friction finger into friction spring, and press on.
‒Always use protective gloves, and only exert pressure at centre of glass. [/ul][/ul]
Friction finger
â—†When installing the mirror glass, friction finger -8- must be inserted into friction spring -9- in housing. [/ul]
Friction spring [/ul]
you dont need that at all just move the mirror so you can get a finger in there and then slowly gently pry it out then carefully pull the 2 clips off because if youre not carefull both ends will come off the mirror.
