Not Good
Old Jan 26, 2008 | 05:47 PM
amiller86's Avatar
Default Not Good
Ok, sotoday I had theAPR program (93 oct) flashed on my ecu, it drove pretty great right after i got it. However, i went to go drive it again this evening and BIG problems! It idles ok, but as soon as you go to drive it the check engine light starts flashing. Also the engine is having problems. When you press the accelerator the engine stumbles, and then makes a noise kinda like a machine gun (bad example I know.) I only made it about 20 ft down the road and had to turn around and park it! I'm pretty sketched out, I would bring it somewhere to have it checked out,but i'm afraid it won't make it, or it will seriously damage something. Anyone had this problem? Know anything about why it happened? Any ideas? I don't have any engine codes to give since this happened about 5 mins ago..
Old Jan 26, 2008 | 05:56 PM
chaos92287's Avatar
Default RE: Not Good
you didn't regap your spark plugs and now your misfiring
Old Jan 26, 2008 | 06:06 PM
amiller86's Avatar
Thanks Chaos,
Is this something you have to do with all chips? I would have imagined the shop would have said something (then again maybe not.) I think I've see posts about this, I'll search, but in the mean tie do you know what they should be? Or a place where i can find out.
thanks again, i reallyappreciate it
Old Jan 26, 2008 | 06:11 PM
Rhinop21's Avatar
Mine are still gapped at .032 and my car runs like a champ.
Old Jan 26, 2008 | 06:14 PM
amiller86's Avatar
It drove fine on the way home (about 2hrs), it was only after is sat for a while that this problem occured
Old Jan 26, 2008 | 06:30 PM
chaos92287's Avatar
yes it should ALWAYS be done when chipping. regap or replace your spark plugs https://www.audiforums.com/m_732017/tm.htm then disconnect your battery for 10 min to clear the codes. if the flashing cel comes back, get the code read and replace the corresponding coipack
and Rhinop you should regap them immeadiately. takes 10 minutes, and if you dont you could blow a coilpack
Old Jan 26, 2008 | 08:41 PM
amiller86's Avatar
so vermont sucks and i couldn't find a place that carried any bosch plugs. but thats besides the point. that link that you gave me was for plugs on a b5? maybe? anyway, i don't know how to release the coil pack from a b6. there looks like a tab, but i don't want to break anything. somebody please help!!!!
Old Jan 26, 2008 | 09:58 PM
Sherman Banks's Avatar
You should be using NGK bkr6e's (copper) instead of Bosch. The copper runs a bit hotter and they are only about $2 a piece. You will have to replace them every 3-5000 miles, but at that cost it shouldn't matter much. The coil packs are easily pryed up with a flathead screwdriver, at least that's how I get them off.
Old Jan 26, 2008 | 10:26 PM
amiller86's Avatar
is it that tab on the firewall side of the coils? you just pry that up?
Old Jan 26, 2008 | 10:40 PM
http://www.a4mods.com/index.php?page...pperplugs.html Here is a good writeup on B6's plug swap. I use the screwdriver to lightly pry it loose but it shouldn't require much force.
