anyone with a cf hood?
Old Feb 10, 2008 | 03:50 PM
A6Audi's Avatar
Default anyone with a cf hood?
i already posted in the a6 forum since thats what i have but more people with a4's have cf hoods. my question is how can i get the washers to work, the hood strut to work and thats about all i want. there are indents for them but not holes all a stock hood, can i have some one drill them out. it's a vis cf hood. thanks
Old Feb 10, 2008 | 05:21 PM
01afour's Avatar
Default RE: anyone with a cf hood?
i have a vis c.f. hood on my a4. i would no reccomend putting the hood shock back on, it is too strong and will probably end up cracking the hood when you try to close it. i didnt hook up my washers yet so im not exactly sure, but if you pulled the harness off the old hood, just use those and find a way to attach it to the new hood. you can always drill holes, and run it through the hood, but then you have to buy lower profile washers i believe, mine looked like there was no chance of them fitting.
now i have a question for you, aside from clear coating it, do you kno ifthere areany other things i should do to keep it looking fresh?? i cant afford to clear it until the spring so im not sure what i should use to protect it until then.
Old Feb 10, 2008 | 07:12 PM
tooxtreme8813's Avatar
you need to have the holes cut out and dont use the prop rod
Old Feb 10, 2008 | 11:59 PM
A6Audi's Avatar
ORIGINAL: 01afour
paint seal leave it on for 24 hrs then put a wax on it for 24 hrs, and if there are any cats around i would suggest a cover or a shot gun.
Old Feb 11, 2008 | 03:07 PM
01afour's Avatar
whats paint seal? is that like a spray on product? casue thats the only reason im not clearing it now anyway is cause its too cold out. i dont have access to a garage right now, so i need something temp until i can clear it.
Old Feb 11, 2008 | 04:45 PM
A6Audi's Avatar
ORIGINAL: 01afour
no paint seal is somewhat like a cream wax, it's supposed to bind with the clear coat, to make a temp. extra layer of clear coat. it doesn't work that good as they say, but it will add more protection
Old Feb 11, 2008 | 05:33 PM
qUaTtRoA4's Avatar
you are going to need to cut eh hood to get the washer caps back on
as far as functionality, they are nice to have, but as far as looks go, the car generally looks better w/o them
whe hood shock will put too much stress on one point and cause mad spider cracks and possibly even crack through the resin...no hood shock, just keep a stick of wood or a baseball bat in your trunk...
gl!
ladybird
Dec 9, 2013 02:45 PM
Mr. Phil
Jun 4, 2011 04:52 PM
goodsaxx71
Sep 14, 2010 09:36 AM
kt4406
Jul 6, 2007 10:37 AM
