Need Help weird thing
Old Apr 12, 2008 | 03:13 PM
tahoehtp's Avatar
Default Need Help weird thing
I just went to grocery store, when I came back in the car, and start driving, my windows won't open. and noticed that display showing all doors are open. except driver door. even though all doors are shut.
what is causing this?
anyone has any idea?
I can lock and unlock the door with remote after engine is off, but I can't lock etc from the button in the car either.
Old Apr 12, 2008 | 03:19 PM
auditech79's Avatar
Default RE: Need Help weird thing
Like i always say........what are the fault codes?
It could be a blown fuse, or a faulty convience control module.
Old Apr 12, 2008 | 03:30 PM
tahoehtp's Avatar
well I'm at my son's place and not at home, and I don't have cable for vag here.... so that's the prob.
it wasn't doing it when I left just happened when I got back in from grocery store.
all 3 doors except the driverside will show door open. I'll go check the fuse now and see though
Old Apr 12, 2008 | 03:39 PM
tahoehtp's Avatar
interesting. dome lights fuse was out. that does all this thing.....
Old Apr 12, 2008 | 04:05 PM
auditech79's Avatar
Changing the dome light fuse didn't fix the door problem did it?
Old Apr 12, 2008 | 04:46 PM
tahoehtp's Avatar
yeah it did.
is that because of the convinience feature that has to be workin?
Old Apr 12, 2008 | 08:06 PM
auditech79's Avatar
Nah thats just strange, un-less its like a 20+ amp fuse that runs more than just the dome lights.
Old Apr 12, 2008 | 08:34 PM
tahoehtp's Avatar
it was 10 amp fuse. I noticed that when I was driving again (dirt road going 15 mph or so) when I hit some bumps light flashes and burnt the fuse like door is open.
maybe there is short somewhere?
Old Apr 12, 2008 | 10:01 PM
tahoehtp's Avatar
auditech79, where is the module located on 99 2.8 exactly?
I'll have access to vag tomorrow night when I get home. but wanted to check to see in the morning
Old Apr 12, 2008 | 10:56 PM
auditech79's Avatar
The module is under your feet on the driver's side. Pull up the carpet and it should be in a little black box right there.
Check to see if the wiring is rubbing on the body somewhere, or got pinched. Another thing that could do it is a loose bulb, one of the bulbs above your head might have fallen out of its socket grounding out the circuit.
