B6 A4 Shock Replacement - Spinning Shock
Here is the deal. I just pulled one of my front shocks, as i am replacing with a stasis kit, and when i try to get the nut off the top shock mount.
I am using an impact gun and all that happens is the shock rod , the nut is attached to, just spins. I tried a crescent wrench, a pipe wrench and nothing. Wasted all that time and had to put it back together.
Can anybody tell me how to get this nut off??????
:: a4mods.com :: - The Premiere Audi A4 Modification Guide and Pictures Library
I used needle nose for mine and had my buddy hold one while i spun the other.
I used a wrench while he held the pliers. had the bottom of the shock in a too a bit of tugging but it broke free. had the bottom of the shock in a vise to hold steady and twisted from bottom while unscrewing from top. if that makes any sense to you.
Hopefully I will have time to yank the shock out this weekend, but I didn't see the top piece you have pointed out. Thank you and i will take a look. also the bottom of the shock does not keep the internal from spinning on mine. If I don't find it I have heavy duty vice grips.
I am not sure why audi designed the suspension this way, but thank god replacing shocks is a one time thing.
