VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
Audi A4 b7 2.0l tdi 170 help with vag codes
Old 05-09-2016, 04:34 PM
stibs73's Avatar
Default Audi A4 b7 2.0l tdi 170 help with vag codes
Just pulled these faults up as I'm having problems with glow plug light intermittently flashing and when I turn the engine off it seems to shudder to a stop. Also intermittently bad idling and strong smelly exhaust but no smoking. Car runs well otherwise. Thanks in advance for any help.
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUZZZ8EX8A057116 Mileage: 171590km-106621miles
Address 01: Engine Labels: 03G-906-018-BRD.clb
Part No SW: 03G 906 018 AQ HW: 03G 906 018 AQ
Component: R4 2.0l PPD1.3 9971
Revision: --H43--- Serial number: XXXXXXXXXXXXXX
Coding: 0000072
Shop #: WSC 00045 210 83908
VCID: 74E1AA8B1739FD817B3-8021
2 Faults Found:
012546 - Motor for Intake Manifold Flap (V157)
P3102 - 006 - No Signal - Intermittent
Freeze Frame:
Fault Status: 00000001
Fault Priority: 5
Fault Frequency: 16
Reset counter: 38
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 864 /min
Torque: 48.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage: 12.43 V
Torque: 1016.0 Nm
Torque: 0.0 Nm
005214 - Mass Air Flow during Regeneration too Low
P145E - 006 - - Intermittent
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 37
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 1760 /min
Torque: 64.0 Nm
Speed: 58.0 km/h
0.00 %
85.41 %
Mass Air / Rev.: 430.6 mg/str
Mass Air / Rev.: 599.5 mg/str
Readiness: N/A
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BL
Component: A4 Klimaautomat 3233
Coding: 00000
Shop #: WSC 00000
VCID: 6CD1B2EB1C092541A33-5072
2 Faults Found:
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to Plus - Intermittent
00716 - Air recirculation Flap Positioning Motor (V113)
41-00 - Blocked or No Voltage
markj1978
01-09-2017 06:29 AM
Jayroberts
12-14-2015 11:51 AM
NorthernMike
08-31-2012 02:00 PM
kalem
08-07-2011 08:03 AM
contrakid
11-21-2010 10:50 AM
Quick Reply: Audi A4 b7 2.0l tdi 170 help with vag codes
