VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
VAG COM for MAC OS X
Old 10-26-2014, 04:07 PM
majky2158's Avatar
Default VAG COM for MAC OS X
Hello people,
du you know, if exist VAG COM for MAC OS X 10.10?
I have a OBD II cable, but software can be used only on windows. I need use VAG on MAC PC, without installing win 7 or 8 in to VirtualBox, or like parallel system on PC...
Thank you for your answers...
Old 10-27-2014, 07:25 AM
bradtyler02's Avatar
Last I heard, there was no plan to make a Mac compatible version for us smart one that use Mac.
Old 10-27-2014, 02:54 PM
majky2158's Avatar
That`s bet...
And any other software solution, not VAG, but for Mac OS X?
Which can communicate and read mistakes code from the car...?
Old 10-27-2014, 07:01 PM
Not that I'm aware of
Old 10-28-2014, 08:32 AM
innov8's Avatar
I did an extensive search and it was a deadend. Short of running a windows shell on your mac OS system, there is nothing that will run on the mac os. If you find something, pls report back.
Old 11-16-2014, 10:28 PM
nueDi's Avatar
Default using vag on mac
havn't tried it, but you could probally run using Crossroads or Parrellels software, which create a virtual window drive and lets you run windows based software.
or you could always run bootcamp.
I searched Crossroads, and did not come up with anyone who had successfully run it. I did post a tread on the Crossroads/ Codeweaver forum, and will let you know if anyone posts.
Once I get a USB reader and Vag.com, I am planning on running Crossroads.
Might take some tweeking, but should work.
https://www.codeweavers.com/support/...8973#msg168973
Old 01-25-2015, 09:53 PM
rusty1428's Avatar
what version of OS do you have? If you have 10 you can install windows on it and then run the vag-com
Old 02-14-2015, 08:07 AM
williagw's Avatar
I have a BootCamp partition on my Mac that I installed an old windows OS on. Vac-Com works great. The only down side is you have to reboot into Windows when you want to run the Vac-Com software. I also installed eBahn reader for the service manuals on it.
I found that some USB devices that work with Windows on BootCamp do not work with Parallels/Windows on the Mac OS.
Old 05-24-2015, 01:26 PM
snapdragon's Avatar
I use bootcamp and of course it works, as does everything.
Years ago I used virtualbox with winxp and vcds. That works fine too.
Old 05-26-2015, 10:12 PM
Omnigeek's Avatar
I use CodeWeaver's CrossOver software to run Windows applications.
