18 year Old needs help
Old 03-23-2016, 10:06 PM
Trevor West's Avatar
Default 18 year Old needs help
Hi Group,
I just bought my 1st Audi (2005 TT 1.8t)
1 month into it and Ive had to replace all the heater hoses ($500). Then find out its over heating because the "Head is breached" as its not holding pressure. The shop wants $2900 to fix head and do a water pump and timing belt. Am I getting ripped off? It feels like it.
Is there any Audi mechanics in So Cal (Ventura or LA County) that can do the work on the cheap if I get the part. Im paying $300 a month payment and have to take a bus to school and work.
Any advice is appreciated.
Old 07-01-2016, 02:00 AM
949's Avatar
949
949 is offline
head work is usually pretty labor intensive. now I cant say for sure if that cheap or expensive so I'm sorry I cant help you there. all I can say for that is to ask around for prices. remember that you usually get what you pay for unless its someone who is just stealing from you.
Old 10-11-2018, 11:17 AM
JETSPEED333's Avatar
SoCal Crew Member
$2900 sounds pretty steep.. it's a 4 cyl after all.... not mechanically inclined at all? any friends who are? The job is not too difficult...
  • Service and Repair
Toothed belt, removing and installing
Note:
Mark the direction of rotation before removing the toothed belt. If a used belt rotates in the wrong direction when reinstalled, this can result in breakage.
1 - Engine support
2 - 45 Nm
3 - Toothed belt guard, top
  • To remove belt guard, it may be necessary to unbolt retainer for coolant return line (for turbocharger).
4 - Toothed belt
  • Mark direction of rotation before removing
  • Check for wear
  • Do not kink
5 - Idler roller
6 - 27 Nm
7 - 65 Nm
  • Use counter-hold 3036 to loosen and tighten
8 - Camshaft sprocket
  • For exhaust camshaft
  • Note installation position: camshaft sprocket is installed with smaller side facing out and TDC marking for cylinder 1 visible
9 - Tensioner
10 - Washer
11 - Tensioner for toothed belt
12 - O-ring
  • Replace
  • Lightly coat with coolant G 012 A8 D before installing
13 - Coolant pump
14 - 15 Nm
15 - Crankshaft sprocket
  • Contact surface between sprocket and crankshaft must be free of oil
  • Can only be installed in one position
16 - 90 Nm + 1/4 turn (90 degrees) further
  • Replace
  • Counter-hold with 3099 retainer to loosen and tighten
  • Place 2 washers between sprocket and retainer when mounting retainer
17 - 15 Nm
18 - 20 Nm
19 - Toothed belt guard, center
20 - Toothed belt guard, bottom
21 - 10 Nm
  • Removing toothed belt
Special tools, testers and workshop equipment required:
  • 10-222A Engine support bridge
  • 10-222A/1 Bracket for engine
  • Engine in vehicle
  • Disconnect air duct at bottom of right-hand longitudinal member (air duct leads to charge air cooler).
  • Remove sound insulation panels in center and on right (arrows).
  • Remove ribbed belt and tensioning element.
  • Remove coolant expansion tank and power steering reservoir (arrows) and move to one side with hoses connected.
  • Disconnect vacuum hose from EVAP canister and from connection on throttle valve.
  • Disconnect electrical connectors on coolant expansion tank and EVAP canister.
  • Remove toothed belt guard (top).
  • Set up engine support bracket 10-222 A with supports 10-222 A/1.
  • Install retainer 3180 to right lifting eye and attach to engine support bracket 10-222 A.
  • Lift engine slightly with spindle of engine support bracket 10-222 A.
Note:
Lift coolant expansion tank and power steering reservoir and tie them in place on the engine support bracket.
  • Set crankshaft to markings for TDC of No. 1 cylinder (arrows) by turning central bolt on crankshaft sprocket in direction of rotation.
  • Remove vibration damper, making sure not to change TDC position.
  • Remove center and bottom sections of toothed belt guard.
  • Unbolt engine support from engine console and engine console from body (arrows).
  • Unbolt connecting piece between engine console and body.
  • Take out engine console.
  • Remove bolts for engine support (arrows), but do not take out engine support.
Note:
To remove the bolts for the engine support, raise or lower the engine slightly as necessary via the spindles on engine support bracket 10-222A.
  • Mark direction of rotation of toothed belt with chalk or felt pen.
  • Screw M5 x 55 stud -1- into toothed belt tensioning element. Screw hex nut -2- onto stud -1- using a large washer -3-.
  • Only tension piston of tensioning element as far as necessary to secure it with a locking pin (e.g. from lifting appliance 2024A) arrow-.
  • Pull out toothed belt through space between engine support and cylinder block.
  • Installing toothed belt (setting camshaft timing)
Note:
  • The position of the toothed belt must be set as described below, even after repairs in which the belt is only taken off the camshaft sprocket.
  • When turning the camshaft the crankshaft must not be at TDC (danger of damage valves/piston crown).
  • Align camshaft sprocket mark with marking on cylinder head cover.
  • Place toothed belt on crankshaft sprocket (mark direction of rotation using chalk or paint).
  • Install toothed belt guard, lower part.
  • Install vibration damper (note installation position: hole in vibration damper is over projection on toothed belt sprocket).
  • Align vibration damper marking with marking on lower part of toothed belt guard.
  • Install toothed belt onto coolant pump, then tensioning roller, and finally camshaft sprocket.
  • Pull out locking pin (arrow) and loosen piston of toothed belt tensioning element.
  • Remove stud -1-.
  • Turn crankshaft two complete turns in engine direction of rotation, set again to TDC and check adjustment.
  • Install engine support and console.
  • Remove engine support bracket 10-222 A with retainer 3180.
  • Install toothed belt guard (center and top sections).
  • Install ribbed belt and tensioning element.
  • Install and secure coolant expansion tank and power assisted steering reservoir.
Tightening torques
you can rent some of the tools necessary from local parts shops...
manobal
12-29-2013 02:46 AM
sttrebo
09-06-2010 09:27 PM
WyoTT
09-13-2006 10:08 PM
Quick Reply: 18 year Old needs help
