Turbo Help Plz!
Old Oct 11, 2008 | 08:07 PM
9idua7's Avatar
Exclamation Turbo Help Plz!
ok i am going to be putting a new turbo in my 1997 audi a4 1.8t quattro and i want all or any advise i can get !! anything i should be weery of? or any issue that are common, any things i should do b-4 putting the new one on ANYTHING!! i do have the "sea foam treatment" and lucas synthetic with GTX high milage because it has 180,000 miles on it. but is clean and runs perfect and is flawless, (was owned by older couple and garage kept). but im getting off topic, but i was just hoping for any and all advise A.S.A.P.
thank you,
Dylan
P.S. what is the easiest way to get it out, and back in???
Old Oct 11, 2008 | 09:14 PM
ghost6303's Avatar
you should replace the turbo oil lines while your in there. you should be using mobil1 5w30 or 0w40 and M301 oil filter. what turbo are you replacing it with? and why are you replacing it? try posting in the A4>B5 forums you will get alot more response there.
you should try and inject some oil into the turbo before you put it all together, it takes a few seconds between the time you turn the key and the time the oil gets to the turbo for the first time. in those few seconds you can cause a tremendous amount of wear if there is no oil in there already.
03a418tnate
Aug 10, 2010 08:07 PM
mr V8
18
Jun 23, 2006 03:21 AM
DickM
12
Mar 21, 2006 05:15 AM
