Audi A2 This compact Audi A2 offers a lightweight aluminum structure which allows the small yet efficient engine to offer performance comparable to others in its class.
Engine Mangement Light - Code 10074
Old Jan 4, 2008 | 02:00 PM
davendra's Avatar
Default Engine Mangement Light - Code 10074
HI
I have an Audi A2 1.4 TDI 2003.
The engine management light comes on after a while when driving it, It's sluggish and judders.
We hooked it up with the diagnostic tool and got the following error
Error - 10074
p1666 value for pump/injection cylinder n24oe
Any ideas on what has gone and estimate costs ?
I'll ring Audi tommorrow.
Old Jan 4, 2008 | 02:08 PM
techbod's Avatar
Default RE: Engine Management Light - Code 10074
injector 1 circuit break possible cause = wiring circuit/shorts to ground
Old Jan 5, 2008 | 11:20 AM
jessica25's Avatar
Default RE: Engine Mangement Light - Code 10074
Hi all, i also have an A2 1.6 FSI. my engine failure light has been coming on every few months! when it lights i set out on making the trip to Audi service. it first happened on the 30th of May 2007...again on the 7th of october 2007 and i was driving the car home yesterday(4th jan 2008) and it happened again! have booked car in on monday, more time off work. on the 30th may and 7th oct was told the problem was the pisten miss fireing, so on both occasions the coils were replaced, for a lovely sum of 170 euros about £110 pounds, the car judders, the engine sounds like a tractor! also i have noticed a loud knocking noise when i go over small potholes and over ramps..have had this looked at and was told it is nothing. it is getting to the stage that i dont know what to do. Any advice? would really like some feed back. thanks, jessica
Old Feb 6, 2008 | 09:48 AM
king.audi's Avatar
Old Jul 7, 2008 | 09:07 AM
pbuffham's Avatar
Davendra
Can you tell me if you solved your problem? - I think I have the same and it would be helpful if I could use this info to take to the garage.
PB
Old Jul 7, 2008 | 10:01 AM
techbod's Avatar
Davendra only ever made 1 post so I doubt you will get any help there my advice is have it checked for fault codes first
Old Aug 18, 2008 | 05:19 AM
pbuffham's Avatar
Default Techbod
Hi Techbod
Followed your advice and got a code reader for my A2 problems
EM light currently not on but did reader anyway - came up with code 412E - cylinder 2 misfire
With this in mind and the other "Symptoms" of EMS light coming on - usually after I've idled in traffic - flashes on and off, loss of engine power/acceleration difficulty climbing hills etc, then going on to constantly on but slightly better performance- do you have any ideas?
Paula
alinux
Sep 28, 2008 02:34 AM
shkenned
Jul 22, 2007 06:28 PM
SnowSurfns
Jul 9, 2007 11:27 PM
frazertelford
Nov 27, 2006 05:50 PM
akindy
Jul 2, 2006 04:01 AM
