19"s on my AR
Old Jul 27, 2008 | 11:49 AM
LilRobb's Avatar
Default 19"s on my AR
What would be the recommended tiresize for 19"s?
Figured maybe a 235/35 or a 245/40 - prices for 19" dramatically vary with size, any advice?
Robb
Old Jul 27, 2008 | 12:03 PM
MYD WGN's Avatar
Old Jul 27, 2008 | 12:26 PM
LilRobb's Avatar
Default RE: 19"s on my AR
That only recommends the 255/70 size - nobody running other tires?
Robb
Old Jul 27, 2008 | 11:15 PM
white fish's Avatar
seems like 255/40/19 is the proper size
Old Jul 28, 2008 | 06:13 PM
LilRobb's Avatar
Sorry,
that's what I meant...
Robb
Old Aug 10, 2008 | 09:49 PM
white fish's Avatar
tire size is easy its the offset and spacer size you are going to have fun with
Old Aug 11, 2008 | 10:49 PM
LilRobb's Avatar
The 255/40 is significantly more expensive then let's say the 235 - guess it's the load index that doesn't comply?
Robb
Old Aug 30, 2008 | 01:45 AM
mctavish11's Avatar
Robb
well, the load index for the allroad is 97 (1609 lbs per tire), what is the speed rating of the tires you were looking at?
It makes sense for the 255 to be more expensive than a 235, given that it is 20mm wider from the widest point of the outer side wall to the widest point of the inner side wall. Although a 235/40 will have a lower profile than a 255/40, since the "40" represents the sidewall aspect ratio (rim to tread), which is 50% of the section width (the 255 or 235) haha, sorry, i've worked in a tire shop off and on at Costco for the last 5 years when im home for the summers from school.
sorry, this post came later than the originals, but i was bored and looking thru old ones.
Old Sep 2, 2008 | 05:14 AM
andry's Avatar
Old Sep 16, 2008 | 06:37 PM
motomonkey's Avatar
Originally Posted by lilrobb
that only recommends the 255/70 size - nobody running other tires?
Robb
240/40
