How can I get this sound off my car?
Old Sep 3, 2008 | 06:11 AM
audi_1.8T's Avatar
Default How can I get this sound off my car?
I have been getting this squeacking sound from the passanger side.
I'm thinking it's comming from my dash board or glove box...
It occurs when I drive over a speed bumps and bumpy roads...
Really ennoying. lol
I would highly appreciate if someone helps me out...
Old Sep 3, 2008 | 09:40 AM
CRAZYHAWK's Avatar
It could be the ventilation fan or control arm bushings.
Old Sep 4, 2008 | 03:51 AM
audi_1.8T's Avatar
Default hmm
The sounds come from inside of my car.???
Old Sep 4, 2008 | 05:45 PM
auditech79's Avatar
Push down on the fenders, if you can hear the noise you need upper control arms.
Report back after you try it out.
Old Sep 30, 2008 | 04:02 AM
audi_1.8T's Avatar
Still not gone.
I have pushed down my fender. No sound.
Sqeaking sound is really enoying.
Any other place to check?
Old Sep 30, 2008 | 10:03 AM
CRAZYHAWK's Avatar
Turn off the ventilation fan. Do you still hear the sound?
Old Sep 30, 2008 | 11:57 AM
jlaudio184's Avatar
How do your rotors look? Is the outside edge of them scored? I had almost the same problem but when I looked into it turned out to be my pad hitting my rotor, making a squeak. Check and see if the outside edge is scored higher than the rest, if thats it, grind it down alittle so its almost flush with the rest.. solved my problem.
Old Oct 1, 2008 | 04:18 AM
audi_1.8T's Avatar
thanks for your comments. Outside is fine and with the ventelation off still makes the sound. I'm pretty sure that the sound is coming from the inside.
I'm thinking of resembling my dash board.
Old Oct 1, 2008 | 12:00 PM
CaleKessler's Avatar
It won't make a difference. It is an Audi, they all have funky sounds inside. Good Luck, Have Fun, use armorall.....
-C
Old Oct 2, 2008 | 03:38 PM
Rockpundit's Avatar
I think its the coil springs.
grissomtd
Sep 3, 2013 06:41 PM
sineo
Jun 11, 2011 07:38 AM
tribalb
Nov 14, 2007 05:32 PM
richsnipe
May 11, 2005 02:26 PM
