changing language display..
Old Aug 29, 2008 | 01:17 PM
h00kah123's Avatar
Default changing language display..
i own a 2004 a6 2.7 sline package, everytime i start the car up.. her display shows up in french..the manuals doesnt tel me how to change..can anyone help me at this please?
Old Aug 29, 2008 | 01:22 PM
oc_audica's Avatar
probably need change the ecm code to usa via vag-com
Old Aug 29, 2008 | 01:41 PM
h00kah123's Avatar
vag-com?im totally new to all this..can you please brief me ?
Old Aug 29, 2008 | 02:16 PM
oc_audica's Avatar
it is a communication cable that connects to your OBDII port and can read fault codes, log stuff, change module settings etc...
http://ross-tech.com/
Old Aug 29, 2008 | 04:18 PM
h00kah123's Avatar
thank you..
Old Feb 9, 2022 | 06:33 AM
Ultimer's Avatar
Don't worry, I think most people who move to a new country or just start speaking a different language go through this stage. When I started learning Russian, of course, I taught it with online Russian tutors, which helped me a lot, because I specifically chose a native speaker. But nevertheless, I tried to communicate with Russian guys more often, I found them on the Internet and started to chat so as to overcome the language barrier. You just need more practice.
Old Apr 18, 2022 | 06:57 AM
JAcobRavel's Avatar
Have you ever thought about improving your german? I think if you know the basics, it'll be pretty easy for you to improve your language skills, and I can even recommend you check out the best apps to learn german fast. Personally. I use them as well to learn this foreign language, and I can say that they work pretty well.
Old Jul 14, 2023 | 02:42 AM
TheoHernandez's Avatar
It's a very complicated question, but if you can't solve it, you can always use translation services. When I bought my Audi, I was in France, so it was logical that the display was in French and I couldn't change the language either, but I used an english to french translator to explain to the mechanic what was wrong and what I needed to fix, so I solved the problem very quickly. The language barrier is often a very big problem that needs to be addressed immediately.
