-   -   Temp running hot when ideling (https://www.audiforums.com/forum/audi-a3-12/temp-running-hot-when-ideling-2501/)
hh5th Aug 26, 2004 01:36 AM
I have Audi A3 97/98 model.
Just recently temp is going really hot.
I checked but there is no leak in anywhere. Just the steam coming out from coolant container. (Boiling)
I did flushed the radiator and refilled the tank but still goes up high.
I have noticed radiator fan does not run at all. It only runs short time when I unplugg the radiator drainning hole.
Is this thermo problem or water pump problem?
Anyone one ?
:eek:
villageinn Mar 4, 2005 02:27 PM
RE: Temp running hot when ideling
I had the same problem it was a fuse , one of the fuses that are on top of the batterrie .
With ne it semmed ok when i had the air con on but other wise y got very hot so that was the solution .
hopw ive helped
