-   -   Brake squeaking (https://www.audiforums.com/forum/b6-models-70/brake-squeaking-2580/)
audiboy1618 Sep 2, 2004 07:56 PM
Brake squeaking
ok, everytime i come a complete stop i have really really bad squeaking. I just replaced the pads so im thinking rotors? any ideas?
Doose Sep 3, 2004 02:51 AM
RE: Brake squeaking
Did you have the rotors turned before the new pads were put on? If not that could be why. Remember squeeling, or high frequncy brake noice isn't typically indicative of lack of stopping power or anything. I've been looking hard for the mimum rotor thickness. You know, befoe you have to buy new ones and use the old ones as clay pigeons on a skeet shooting range. If you can't grind the old ones cause of lack of proper tools or you think they might be a little thin or warped, I'd just get new rotors myself. HTH
joeypants Sep 3, 2004 01:20 PM
RE: Brake squeaking
My brakes squeak a little too, usually when I first apply them, and or use them gently in traffic. It's quite annoying.
Marcus Sep 3, 2004 06:16 PM
RE: Brake squeaking
Have you cleaned them? I often find that once I cleaned off the brake dust, the squealing disappeared for a while.
Jestnomen Sep 3, 2004 09:14 PM
RE: Brake squeaking
Take a flash light and look at your brake pads to make sure you still have some surface left.
If your pads are still good they make a greese you apply on the back side of the pads that reduces brake squealing.
audiboy1618 Sep 3, 2004 09:28 PM
RE: Brake squeaking
thanks jestnomen, yeah i just put new ones one
Jestnomen Sep 3, 2004 10:27 PM
RE: Brake squeaking
If you replaced your brakes yourself then this should be cake. Also, did you bed your brake pads in correctly?
http://www.formatc.org/freelander/brakes/brakes82.jpg
David_K Sep 4, 2004 12:54 AM
RE: Brake squeaking
Your calipers are misaligned. its a very common problem that is easily fixible with a 13mm box wrench
ImolaS4 Sep 4, 2004 07:17 AM
RE: Brake squeaking
I'm with Jestnomen on this. If the pads weren't bedded properly, then you'll most likely have squealing at low speed braking.
03A41.8T Feb 8, 2008 09:38 AM
RE: Brake squeaking
What does "bedding" brake pads mean?
