-   -   Half the sound. (https://www.audiforums.com/forum/audi-a6-9/half-sound-18403/)
heisse_mkII Oct 20, 2005 03:43 AM
Half the sound.
My right side speakers don't work. If I roll down the passenger side window, it'll come on but you have to hit just right. Also going around right hand turns it'll work. It is the whole side that is out and it all comes back on on the right window position or around the turn. Where should I look for a loose connection in the door. Any help would be appreciated.
mjollnir Oct 29, 2005 08:16 AM
RE: Half the sound.
The door panel comes off very easily, 2 screws i believe(phillips head). after that look down by the speaker, and all around the foam insulation, there are multiple wiring harnesess..should be able to see from there. (I changed out my two fronts with more expensive ones, and it really is an easy job). just becareful to not drop the panel soon as you unscrew the screws because there are Many connections that you wouldnt want to break.
heisse_mkII Oct 31, 2005 01:19 AM
RE: Half the sound.
I fixed it yesterday. It was just the upper speaker electrical plug which was disconnected. Taking the door panel off was the easiest.
beefski Oct 31, 2005 01:56 AM
RE: Half the sound.
i have to remove mine as well for speaker repair
what system is in it? bose?
how many plugs?
heisse_mkII Nov 4, 2005 03:17 AM
RE: Half the sound.
Yes it is the Bose system, but I'm not sure excatly how many connectors. I didn't fully take the foam part out when I took of the panel. I think there might be 2 or 3 connectors.
