2001 Audi A3 - Need to remove stereo!
Does any1 know how to remove the standard stereo system from the dash?? I noticed there are to slots at the bottom of it to the keft and right. Any Help would be appreciated. Thanks
RE: 2001 Audi A3 - Need to remove stereo!
Basically all you need is two thin flat pieces of metal or plastic, like nail files. If you push these far enough into the slots in a straight line, you will disengage the springy pieces of metal holding the radio in place and you can then pull the whole unit out of the slot.
Hope this helps. |
Ill give it a go,
Many Thanks |
| All times are GMT -4. The time now is 06:57 PM. |
