-   -   Just hit 60,000 miles (https://www.audiforums.com/forum/audi-a6-9/just-hit-60-000-miles-3587/)
rguinto Nov 8, 2004 08:49 PM
I bought my Pre Cert Audi A6 last year with 46000 miles and I just hit 60,000 miles. I was think of replacing the timing belt. Can anyone give me a ruff est of how much that may cost? Or if there is anythng else I should replace?
Jestnomen Nov 8, 2004 11:55 PM
RE: Just hit 60,000 miles
probably 250-300 in parts, and 800-1000 in labor at the dealer.
yergyg Nov 9, 2004 12:08 AM
I recently went in for a routine oil change and the service guy was kind enough to remind me that at 60000 the car should get a tune up, which entails replacing the timing belt and also some 'pump'. I guess in order to get at the belt they have to remove this 'pump' and they've experience problems in the past that have told them to just replace it with a new one vs. putting the old one back (I know it's an odd story). To answer your question though, to get everything done they recommended, it was gonna cost $1400.00
clconversion Nov 9, 2004 12:47 PM
Which engine do u have in your A6 2.8, 2.7, 4.2
yergyg Nov 9, 2004 01:37 PM
2.8
clconversion Nov 9, 2004 01:49 PM
ok I can give you canaidian dealer prices there is a kit out the know for this car makes it cheaper the kit includes the belt the roller & tensioner for $254.00 also you should replace the water pump when doing this job its just preventive maintance that is $170.00 and the labour for this job at the dealer we charge 6.5hrs at $91.95 remember these are Canadian prices
Meticode Nov 9, 2004 04:07 PM
I just replaced my timing belt at 98,000 miles. I didn't do it through a dealer but a guy who works on import cars and it ended costing $465. He replaced the timing belt ($75), another belt ($65), fuses for the cig lighters, and he even found the CD changer 8-pin plug in the trunk for my cd changer that I couldn't find. His labor was $60/per hour, was about an 4 hour job or so. I heard you should get your timing belt replaces every 90,000ish miles. 60,000 seems a bit too early. Unless something is already wrong with it.
clconversion Nov 9, 2004 04:11 PM
your guy didn't replace any tensioners rollers or water pump ? its just preventive maintance and if that tensioner seizes there goes you belt
Meticode Nov 9, 2004 04:24 PM
ORIGINAL: clconversion
I believe he replaced the tensioner rollors too. Not the water pump. He did a maintaince check on what needed to be done with the car and pretty much everything was in very good condition.
clconversion Nov 9, 2004 04:30 PM
ok at least the tensioner were done just want to give you a heads up on what the dealers replace when doing this job
