A4 Service Intervals
Service every 1,000mi/1,600km or 1 month
Check engine oil level Check air pressure in all tires Service every 5,000mi/8,000km or 5 months Change engine oil Change engine oil filter Check engine coolant level Check power steering fluid level Check brake fluid level Check windshield washer fluid level Check air pressure in spare tire Check water drain valve in plenum chamber Service every 15,000 miles / 24,000 kilometers or 12 months Change engine oil Change engine oil filter Replace climate control dust and pollen filter Check engine coolant level Check power steering fluid level Check brake fluid level Check transmission fluid level Check electrolyte level of battery Check brake pad and rotor thickness Check CV boots for cracks Check windshield washer fluid level Check air pressure in spare tire Inspect engine for leaks Clean guide rails of sliding roof and lubricate with silicone spray Check water drain valve in plenum chamber Check engine idle speed (not for models with ODB) Check OnBoard Diagnostics (OBD) fault memory and clear if necessary Service every 30,000mi/48,000km or 24 months Change engine oil Change engine oil filter Replace air filter element Replace spark plugs Change brake fluid Replace climate control dust and pollen filter Check engine coolant level Check power steering fluid level Check transmission fluid level Check electrolyte level of battery Check brake pad and rotor thickness Check CV boots for cracks Check windshield washer fluid level Check air pressure in spare tire Inspect engine for leaks Clean guide rails of sliding roof and lubricate with silicone spray Check tension and condition of timing belt Check dust seals on ball joints and tie rod ends Check water drain valve in plenum chamber Check engine idle speed (not for models with ODB) Check OnBoard Diagnostics (OBD) fault memory and clear if necessary Service every 45,000mi/72,000km or 36 months Change engine oil Change engine oil filter Change automatic transmission fluid Replace climate control dust and pollen filter Check engine coolant level Check power steering fluid level Check brake fluid level Check transmission fluid level Check electrolyte level of battery Check brake pad and rotor thickness Check CV boots for cracks Check windshield washer fluid level Check air pressure in spare tire Inspect engine for leaks Clean guide rails of sliding roof and lubricate with silicone spray Check tension and condition of timing belt Check dust seals on ball joints and tie rod ends Check water drain valve in plenum chamber Check engine idle speed (not for models with ODB) Check OnBoard Diagnostics (OBD) fault memory and clear if necessary Service every 60,000 miles / 97,000 kilometers or 60 months Change engine oil Change engine oil filter Replace air filter element Replace spark plugs Replace accessory drive belt Replace timing belt Replace timing belt tensioner pulley Replace timing belt idle roller Replace water pump Replace coolant thermostat Change engine coolant Change brake fluid Change power steering fluid Replace climate control dust and pollen filter Check transmission fluid level Check electrolyte level of battery Check brake pad and rotor thickness Check CV boots for cracks Check windshield washer fluid level Check air pressure in spare tire Inspect engine for leaks Clean guide rails of sliding roof and lubricate with silicone spray Check tension and condition of timing belt Check dust seals on ball joints and tie rod ends Check water drain valve in plenum chamber Check engine idle speed (not for models with ODB) Check OnBoard Diagnostics (OBD) fault memory and clear if necessary |
| All times are GMT -4. The time now is 02:21 AM. |
