[Deleted]
[Deleted by Admins]
RE: 1998 Steering Noise
check steering fluid
Mitaka,
I have a '97 A8L with 158000 miles. It has a metallic rattle/knock associated with turns on rough roads. Has had a rack rebuild and full front suspension rebuild recently so I'm confident the problem doesn't lie there. The noise seems to come from inside the instrument cluster area - where the steering column goes through! There is no play on the steering at all, so my guess is that it is a worn bush around the column. If I apply a reasonably heavy pulling force on the steering wheel it seems a little better too. Hope this helps, Paul . . . . p.s. I've driven about 12000 miles, high speed, with this 'problem' and I'm not worried except that I hate the noise. |
| All times are GMT -4. The time now is 06:32 PM. |
