A6 TRANSMISSION OIL CHANGE
Old Jan 6, 2005 | 04:19 PM
mitao2000's Avatar
Default A6 TRANSMISSION OIL CHANGE
hi is anybody know when the transmission oil should be changed in an A6 4.2 2000.my car got 60000 and the oil has never been changed?how about the rear differential oil change?rhanks and the transmission oil change should be done in a particular way?(with the engine running?)thanks .mike
Old Jan 6, 2005 | 05:01 PM
CRAZYHAWK's Avatar
Default RE: A6 TRANSMISSION OIL CHANGE
Audi doesn't have a recommended Trans. fluid time or mileage. Many on the forum do it at 100K mi. Need to use VW fluid. Temperature of the fluid must be monitored to correctly refill. PITA
Old Jan 11, 2005 | 12:50 AM
wh22366's Avatar
All I can tell you is to get it done. I didn't, even though I knew better, and it cost me a transmission. Obviously Audi likes to sell new cars. A good tranny shop can handle the special fluid, temp and level requirements.
Old Jan 11, 2005 | 06:48 AM
dane's Avatar
You can do the transmission fluid change yourself if you have the fitting for the filler plug in the tranny. Be sure and follow the service instructions (i.e. engine running and transmission temperature monitored with the VAG unit). Ideally you need access to a vehicle hoist (I have to use a pit and it is a nuisance having to climb in and out!).
jaesae84
May 26, 2012 09:52 PM
sttrebo
Nov 27, 2011 02:56 AM
shazoo
B8 Models
Mar 4, 2011 06:22 AM
audi4a
Jan 12, 2008 07:48 PM
tom1222
Mar 21, 2005 12:50 PM
